1999 F-150 4.6 coil pack question
Old Aug 20, 2010 | 10:54 AM
kitchenguy's Avatar
Hello again,
Getting code 304 for #4 missfire, which it is. Can the coil pack be bad where only one plug is effected? You would think if the coil pack for a given cylinder bank were bad all plugs on that side would be effected? Also is there a DIY way to determine if a coil pack is bad?
Thank you in advance
Old Aug 20, 2010 | 11:16 AM
jbrew's Avatar
Yes to your first question. - 304 is a dead hole. Coil pack, plug wire or plug.
No, this is your layout -
Old Aug 20, 2010 | 11:20 AM
jbrew's Avatar
Just pull the plug wire, throw a plug into it and fire it up. Ground that plug and it should spark. If not, check the wire, then the coil.
Old Aug 20, 2010 | 02:34 PM
kitchenguy's Avatar
Thanks very much for your reply. All wires were pulled and tested with a spare plug grounded and all fired nicely. Stumbled on to another post where you recolected that the wiring harness, if too close to the AC accumulator would also cause a miss-fire in #4. Reading this, a light bulb went off in my head, remembering that I had removed the the electrical block to gain access to the accumulator but never charged the system and left the bolts loose and one missing for a future time. Thinking now with all bolts in and torqued the miss-fire will be eliminated?
Thanks again!
