1997 4.6 help
Old Aug 14, 2010 | 12:46 AM
1997f50's Avatar
1997 4.6 help
ok hey whats up guys i have a 97 f150 172,000 miles on it and i have trouble when i giv it alot of gas it has a low idle and runs rough when giving it alot of gss at 17-2500 rms what do i do?
Old Aug 14, 2010 | 01:13 AM
Have you been following the maintenance schedule? When was the last time you changed the spark plugs, plug wires, air filter, gas filter, etc.? Have you ever cleaned the throttle body, IAC, and MAF? Is the CEL on, are there any stored OBD2 codes?
It could be just about anything. Pretty hard to diagnose over the Internet without a lot more detailed info.
Old Aug 15, 2010 | 09:43 PM
1997f50's Avatar
changed plug wires. and when i changed the plugs the cylinder #4 was stuck so i took a cheater bar and gave it everything i had. it came out but not without at least three threads stuck to it. it tightens down but not for long. i changed the oil bout 1000 miles ago, and the fuel filter when i did the oil, so i dont know what i should do. several people told me to go to napa and get a coil to put in it? i dont know if i could do that myself and the code was cylnder 4 missfire but ive done all that and the coils working and so are the wires ive checked all of them to make sure and the plug fires i took it out and saw it spark so idk wht to do?
Old Aug 15, 2010 | 10:36 PM
jbrew's Avatar
Crap man, try using a little punctuation and allot of spell checking before you post. That gave me a headache trying to figure this one out. I gave up.
Old Aug 16, 2010 | 01:09 AM
Sam I Am's Avatar
http://www.timesert.com/html/ford_sparkplug_faq.html
Old Aug 16, 2010 | 12:37 PM
1997f50's Avatar
ok i think i fixed everything
