hose on VMV to Intake manifold-Replacement
Old Aug 12, 2010 | 10:49 PM
2002 wonderboy's Avatar
Just wondering if there was a better replacement for the hose between the vapor management valve and the intake manifold hose. I replaced the hose 3-4 years ago, now it is breaking down and cracking again. anyone else used anything other than a direct factory replacement or just some fuel vapor vent hose???
Reason is, i was checking under the hood for vaccum leaks, and found that hose leaking. Oh well, I guess 3-4 years isn't bad for a piece of hose I got for free!!!
Old Aug 12, 2010 | 11:25 PM
jbrew's Avatar
That's your EvapEmissionReturn line. Runs from the plenum to your EEP valve on the firewall. I think that's what your referring to.
Replace with the same line. Fuel Vapor for EVAP system. Ordinary hose will collapse and suck shut.
