Help please fuel pump replacement
Old Aug 1, 2010 | 04:49 PM
rglass62's Avatar
i am haveing hell with changeing my fuel pump right now i droped the tank on mine and rased the rear end but still cant get all the lines off the tank and drop it down far enough without stressing the fuel lines not enough room for my big *** i guess. im at the point now where im going to let the tank hang and rase the bed dump truck style. how heavy is the bed ? do you think two people can rase it ? and is there anything i need to watch out for thats not ovious while lifting the bed ? will the fuel disconnect tool you use on the fuel filter work to disconnect the tank lines? i know it has two sizes on it. im sorry for so many questions but i have never done this before and want to make sure its done right the first time. plus this is my only driver and my mother wants her car back ASAP LOL!!! any help i can get would be greatly appreciated thanks.
Old Aug 1, 2010 | 06:41 PM
rglass62's Avatar
come people i know someone here has changed a fuel pump dump truck style before that can anser my questions ???
Old Aug 1, 2010 | 06:59 PM
srfd44's Avatar
I did my 1998 with out bed removal. Just proped the tank on some blocks enough to get my hands over the top. The vent lines (there are 2 of them) are barbed fittings and gave me the most trouble. If you twist them enough, they will come loose. The fuel and return lines are the same as the fuel filter, you will need to insert the release tool to get them off.
The bed is not heavy for two people, but since you are half way there from doing it from te bottom, I would continue.
Old Aug 1, 2010 | 07:05 PM
jbrew's Avatar
That's crazy, - you don't remove the bed for a pump swap. I pull mine every other year just to clean the sock. It's cake, very easy. I'm not sure what your having problems with ?
Old Aug 1, 2010 | 07:08 PM
rglass62's Avatar
ok thank you its hell when you are pushing 50 but i guess i will go for round #4 under the truck lol. and btw if i cant get the vent lines off do you think i can cut them and replace them with something auto zone might carry?
Old Aug 1, 2010 | 07:18 PM
jbrew's Avatar
Their twist locks. You need WD40 and a screw driver to work into the seal. But! You only need to remove the very rear vent completely, - to siphon the fuel before you start, is it to late lol.
Drop the tank down enough/ pinch and slide hose clamps back/ take an awl or a pik of some sort, slide between the hose and vent connect, just a little. Now give it a shot of WD40 and work the hose loose with the tool you using/ Pull the hose from the vent.
Old Aug 1, 2010 | 07:19 PM
rglass62's Avatar
jbrew
Senior Member Join Date: Oct 2005
Vehicle: 1998 Ford F150 SC 4X4 5.4L
i am haveing trouble getting the tank to drop far enough down to get the vet lines and fuel lines off still think it would have been easyer to take the 6 bolts from the bed off and rase it up however i am half way there now with the tank drop. and 4x4 = more room to work
and if it was a cake walk for you your first time your a better man then me.
Old Aug 1, 2010 | 07:22 PM
rglass62's Avatar
jbrew
Their twist locks. You need WD40 and a screw driver to work into the seal. But! You only need to remove the very rear, - to siphon the fuel before you start, is it to late lol.
thanks il give it a try
Old Aug 1, 2010 | 08:49 PM
jbrew's Avatar
Nah, it was easy, - First time I used two jacks, - second and now I use just one , - maybe. Tanks light when empty.
Inside the tank after cleaned -
Pump serviced -
Vents -
See that little rubber section below, - that's where they can split -
Old Aug 1, 2010 | 09:02 PM
rglass62's Avatar
Nice job! and thanks for the pics JBREW to bad your not a neighbor of mine and BTW i thought you said you changed you socks twice a year they look a little dirty to me.
Old Aug 1, 2010 | 09:19 PM
jbrew's Avatar
Thanks, - Nope , I clean mine and that is still dirty in the pic. They come off so you can flush them out.
Old Aug 1, 2010 | 09:59 PM
Hate to ask how often he changes his underwear...........
Old Aug 1, 2010 | 10:31 PM
jbrew's Avatar
Yea, I hate change. Not even sure if I got that one on the calender this month. (?). Ahh, - It's still early
