Powered Door Swap HELP
Does anyone on here know how to wire up powered doors?
My project F150 has got manual windows and locks, and I'm swapping it all out (complete doors) for powered ones.
I've done plenty of modifications in my day, but thought I'd ask before I tackled this project alone.
Normally, in a truck that is equipped with the electrical options, you would have two different systems to deal with.
1 the electric lock system and
2. the power window system.
Best bet is to get a copy of the Haynes manuel and look at pages 12-25 and 12-26 for the circuits involved.
The power windows are usually controlled via the GEM module you may not have in your truck.
There is really no reason you cannot modify/ wire the systems for common manuel control and power as long as you also fuse circuits for fire protection.
Just that you won't have all the fancy control over both actions that a factory system would have afforded.
Good luck.
Good luck.
