interior dash lighting ? (custom console)
Old Jul 18, 2010 | 04:34 PM
woopigsooie's Avatar
wondering if anyone knows of a good lighting wire to tap under the dash pref in the middle.... i am going to put some lights in my navigator console and want them to work with my dash lights. any help is greatly appreciated
Old Jul 18, 2010 | 05:44 PM
kp02-150's Avatar
there's definitely a lead going to the radio you should be able to tap into, although I don't know how much you can hang off of it. i was going to put a toggle in it because i always drive with my lights on, and auto-dim is a drag in the daytime.
Old Jul 18, 2010 | 11:14 PM
MikeWilder21's Avatar
woopigsooie, what does your navigator console look like? im thinking of making one for mine and taking out my factory console.
Old Jul 19, 2010 | 12:03 AM
mustangjonny84's Avatar
Woopig, I think you should be ok hooking up to a wire for the stereo. Do the OEM stereos dim with the dash lights? If so (and if you have an aftermarket stereo) this wire might not even be used. I don't know...I just remember that my OEM stuff has always dimmed with the dash lights and the aftermarket stereos were always of the same brightness.
If you can get the extra couple feet of wire, it should be pretty easy to tap into the fuse that powers the dash lights. Does your Nav console not have any power in it? I did this to get some lights inside my console's storage...but I don't know if your console has a cigarette lighter in it. But if you can get onto the same fuse as those lights, it should function the same.
PS-I always wanted a console/buckets in my '98 STX...hope this helps!
Old Jul 19, 2010 | 12:38 PM
jonny, i have the oem stereo and it does dim
mike, there are pictures of it in my gallery
from what i can tell in my haynes book. it should be the light blue/black wire
Old Jul 19, 2010 | 01:13 PM
thejake1989's Avatar
ill be watching this one. ive tapped into the brown wire from the headlight switch that sends power to the parking lights for stuff before. and ill be loading my console up with leds as well
Old Jul 19, 2010 | 01:56 PM
Sounds good. I don't think OEM stereos use that much power so (as long as you're using LEDs) I think you'll be fine using that wire. Just my opinion, of course. I'm no electrician...but I would say that the worst case is you'd have to put some electric tape on a wire if it didn't work.
I think the blue/black is your best bet. That will give you 12V when the key is turned on. I don't think that'll dim...but I don't even know if LEDs will dim anyway.
Good luck and I look forward to seeing pics!
Old Jul 19, 2010 | 02:18 PM
or tap into the AC panel has lights on it as well
Old Aug 7, 2010 | 11:22 PM
got my console wired up and very happy with the results. gonna post some pics in a new thread
