Need some help!!!
Old Jul 17, 2010 | 07:57 PM
thepizzle44's Avatar
Need some help!!!
running out of ideas here........truck wont turn over completely......battery, starter, fuel pump are all fine.....replaced ignition switch......what else can u guys think of? it has fuel pressure all the way to the rails im just thinking it has something to do with the injectors.........is there a relay or a fuse that controls the injectors at all?.....any help is appreciated. thanks
Old Jul 17, 2010 | 08:50 PM
"Turn over completely" - do you mean it cranks but won't fire off? You either have no fuel or no spark. Pull a spark plug and look at it/smell it - If it's wet with fuel, you have a spark issue. If it's dry, you have a fuel issue. Have you reset the fuel inertia switch? Do you have PATS, and if so, what's the "Theft" light doing?
It would help if you filled in your profile with year, model, and engine.
Old Jul 17, 2010 | 09:05 PM
LOGANSTANFORTH's Avatar
Check the main ground for the PATS...I learned this today, I got the nose tore off my truck and it wasn't grounded and it wouldn't start...Does the radio flash quickly, does the THEFT light flash quickly, if it has a digital dash, the mileage will show up as dashes instead of numbers...Should be 2 thick wires on a big ring terminal...
Old Jul 17, 2010 | 09:30 PM
2000 f150 v8 4.6 auto
it cranks but wont fire off......the mileage shows up as numbers so i dont think its the pats.....i put some starter fluid through the intake and it will start completely for a few seconds then turn off......im kinda running out of ideas here
Old Jul 17, 2010 | 10:06 PM
That probably means the injectors aren't firing. Have you scanned the OBD for codes? Have you put a fuel pressure gauge on the rail?
Old Jul 18, 2010 | 08:19 AM
thats what im thinking too......the rail is pissing out gas and there are no codes being thrown
Old Jul 18, 2010 | 11:48 AM
bump
Old Jul 18, 2010 | 03:27 PM
Have you put a gauge on the rail? Just because it's pissing out gas doesn't mean it's at sufficient pressure.
Old Jul 18, 2010 | 07:18 PM
i'll see if my buddy has a guage and check it out......if that is the problem what could be a remedy in that situation
Old Jul 18, 2010 | 10:17 PM
Fuel pump or fuel pressure regulator.
Old Jul 18, 2010 | 10:51 PM
replaced the fuel pump so thats working fine......i'll check out the fuel pressure regulator tommorrow
Old Jul 18, 2010 | 10:54 PM
maddoughboy's Avatar
or the filter since it could be clogged and not letting enough fuel through.
