f-150 rought start
f-150 rought start
This post is for my dad he has a 2003 f-150 5.4L auto 4 door 4x4 lariat with 170k miles and today i went to start it the engine started kicking so i put it in reverse and it continued to kick and the truck had 1/4 of a tank if that matters. so half ways down my block it stopped kicking i was thinking it was a coil b/c we have the same truck and mine did the same thing when i would start it when i had a bad coil/plug so i got on it to see if it would pop or backfire but nothing. This is a truck that's been everywhere its seen sand, mud, dust, dirt... and the check engine light inst on so i was wondering if it would be doing this because it needs a new air filter, fuel filter or injector cleaner i figured i would ask before he start spending money on something he didn't need
Mike
Mike
Oh sorry yeah it cuts out and it will shake the engine and the truck a bit i think I'm going to unplug the coils and plug them back in maybe shes got a bad connection I HOPE.
thanks
Mike
thanks
Mike
Sounds like a wiring problem then, -if all eight are cutting out or close to it. Like maybe the Crank sensor harness/connector. Or CMP. It could be the battery as well.
I unplugged all the coil connectors and plugged them back in then i waited for 5mins then I fired her up then she ran fine even took it for a 50mile drive little freeway and city and she worked fine so I'm guessing it was a bad connection but thanks for the tips everyone
Thank
Mike
Thank
Mike
