1998 Ford F150 wont Start!
Old Jun 17, 2010 | 03:53 AM
RmP82's Avatar
i changed the head gasket and all the other gaskets, cleaned everything before i put it back in , finally got everything together and had to jump the truck because the battery was low, started after the second attempt and stayed on for about 2 minutes then it shut off and now it wont start , i crank it and hear a loud cranking noise ( sounds like the started and the flywheel) but it will not start, someone PLEASSEEE. help.....suggestions?? solutions?? anything...
Old Jun 18, 2010 | 03:58 PM
Tazmanic's Avatar
Fuel reset switch?
Old Jun 20, 2010 | 02:19 AM
RmP82's Avatar
Nope not that either checked..the reset button is down...Its wierd got a new starter, got fuel, got spark, the damm thing still wont start....
Old Jun 20, 2010 | 07:49 AM
torkum's Avatar
I would go back and double check the timing marks.
Old Jun 20, 2010 | 01:23 PM
Bluegrass's Avatar
If it started and run once, then it most likely is assembled right.
You either lost fuel or ignition control.
Crank position sensor plug,
Cam position plug,
Loss of fuel.
The fuel pressure can be tested without starting the motor.
Ignition by cranking.
See which avenue the issue is, first.
No crank position sensor and nothing works.
No cam positon no fuel injection.
etc.
Good luck.
