My trailer project... just finished today!
Old May 23, 2010 | 11:43 AM
SkyBound85's Avatar
Yeah I'm looking for something that will be great for trails and a bit of mud, but come hunting season I will need to put it to work. It's basically a pleasure/camping/hunting machine. I have heard amazing things about the Yamaha Grizzly's and the Honda Foreman's... I think something around 500cc would be good for me, and 4X4 is a must. I don't know much about the Kingquad.
Old May 23, 2010 | 12:13 PM
DarkShadowSTX's Avatar
Looks great. You going to paint "Ramp Master" on the front again?
Old May 23, 2010 | 12:14 PM
SkyBound85's Avatar
Hahaha no way! This baby is a homebuilt!
Old May 23, 2010 | 01:31 PM
pmason718's Avatar
Great transformation, looks good
Old May 23, 2010 | 01:35 PM
Halverso_99's Avatar
Trailer looks great man.
Old May 23, 2010 | 09:07 PM
SkyBound85's Avatar
Thanks again guys. Does anyone have any recommendations as to what PSI to run my tires at? They are:
Carlisle Sure Trail ST
ST215/75D14
Load Range C
Max Load 1870lbs @ 50psi COLD
Right now they are at 37psi per side.
Old May 25, 2010 | 09:42 PM
Fordfan4life199's Avatar
Great job man looks great. Thought the first pic was final product but boy was i wrong haha.
Old May 26, 2010 | 01:04 AM
Toyz's Avatar
Looks good. I built a trailer almost 8 years ago that sees more abuse than any trailer should have to, over loaded and neglected as it is.. we used a marine grade plywood. Was like $40 a sheet though but looks almost as good as it did the day it went in, with no sealant or paint. Its like a pressure treated plywood. But that looks good. I like the tight knots.
Old May 26, 2010 | 10:44 AM
SkyBound85's Avatar
believe it or not, i inquired about marine grade plywood... they quoted me $126 per sheet of 4X8 in 3/4 inch! the stuff that i went with was 3/4 inch exterior grade spruce plywood, nothing too special, and that was $33 per sheet.
Old May 26, 2010 | 11:35 AM
Toyz's Avatar
Wow, I guess thats whats nice about being in Oregon. Lumber costs are cheap since logging is local and there are 5 local saw mills within a 50 mile radius.
Old May 26, 2010 | 12:26 PM
Dream150's Avatar
What kind of paint did you use? Did you have it sand blasted before?
Old May 26, 2010 | 12:48 PM
SkyBound85's Avatar
no sandblasting, just a fine grit sand paper on the edges to get rid of saw burs. i used a generic clear waterproofing stain that had the viscosity of water and really soaked into the boards.
any recommendations for tire pressure to run?
Old May 26, 2010 | 03:01 PM
Dream150's Avatar
What kind of paint did you use on the frame is what I ment....
The tire pressure should be in the tire.
Old May 26, 2010 | 03:07 PM
grizzstang's Avatar
ST215/75D14
Load Range C
Trailer tires should be run close to or at the max pressure. I would run those at 48 cold if the max is 50.
As for a quad I have a Yamaha Grizzly 700 with power steering. It is a great all round machine. I ride in all conditions from dry trails to mud and deep snow in the winter. It handles everything well. Everyone I know that bought a smaller quad in the 500 range has upgraded to a big bore for the torque increase. If I was looking for a new machine now I would have a Yamaha Grizzly 700 or a Can Am Outlander 800 on my list but a Suzuki King quad is a solid machine too.
