What destroyed my gears?? (pics)
Old May 22, 2010 | 05:18 PM
kingbrian's Avatar
my spiders, the ring and pinion are fine.. All the bearing are good. I got into it to replace the axle seals and outer bearings and i found this. There wasnt any noise, vibes or anything. the axle gears are the same i just havent taken pics. heres some pics.
any input???
Old May 22, 2010 | 05:28 PM
whackemnstackem's Avatar
damn. too much heat, not enough gear oil would be my thought
Old May 22, 2010 | 05:54 PM
illness95's Avatar
with that much metal floating around in the rear end.. its just a matter of time before u wipe out the bearings and start having some reallll big problems..
Old May 22, 2010 | 06:21 PM
kingbrian's Avatar
well i have reason to believe that its been into before since theres a gasket in there with a buncha silicone the oil was changed and all cleaned out.. i dont know if the bearing were changed but i suspect it. some one definitely got in there and cleaned it up..... do spiders wear out???
Old May 22, 2010 | 06:52 PM
spiders dont usually wear down, especially not with chunks missing like that. Something bad happened to that diff and was put back together half assed
Old May 22, 2010 | 07:00 PM
JMC's Avatar
JMC
25 Year Member
The 8.8 differential does not like pushing a truck around. They Pinion and side gears eventually chip and the rear end gets destroyed.
Old May 23, 2010 | 05:02 AM
kingbrian's Avatar
interesting.... so there is a small chance this could be just wear and tear on my well used 210k mile 97 4x4 4.6 SCAB that has alot of heavy towing miles? i hope thats the case.. im really leaning towards 4.10's at the moment since i am in it already.. you think 4.10's with be nice for me as a commuter now, i have 285/75/16's with 3.55's now..
Old May 23, 2010 | 07:53 AM
illness95's Avatar
i made the switch to 4.10s.. worth every penny..
Old May 23, 2010 | 04:06 PM
JMC's Avatar
JMC
25 Year Member
While the 8.8 should last for hundreds of thousands of miles, yours did, imho the 8.8 does not belong in the F-150. After abusing mine and destroying it three times, even with a girdle, it was replaced with a 9.75.
Old May 23, 2010 | 08:13 PM
illness95's Avatar
depends on your abuse.. mine in a stock truck works perfectly.. and i beat the hell outta my truck..
