stuck bushing help!!!
Old May 21, 2010 | 03:10 PM
TDS715's Avatar
putting my body lift on now. only have 2 body bolts left and they are whats holding me up.
both ar front of cab pass and drivers kick panel. the bolts threads downward into the bushing. however the threaded part is just spinning in sie the bushing.
any ideas tips tricks? voo doo dances?
Old May 21, 2010 | 04:22 PM
JMC's Avatar
JMC
25 Year Member
Soak the snot out of it with PB blaster. If that fails cut the bolt and remove it from the bushing and or replace the lower bushing.
Old May 21, 2010 | 08:15 PM
illness95's Avatar
if u have access to torches.. heat the bushing threads up
