what do you guys think???
Old May 20, 2010 | 04:35 AM
mluna84's Avatar
here is my dilemma: the rear end in my truck has started howling, so i know its time for a rebuild...my truck is an '03 screw w/ an 8.8 rear end..i want to install 4.88's however i was told that it is not recommended to put 4.88's in an 8.8... I would like to swap my rear end for a 975, which i can get for about $500, but by the time i put the gears in that, i'll probably be looking at around $800 bucks! With money being tight right now ( I just lost my job, mortage payment is #1 priority!!) I would like to make the most cost effective decision. so i guess my question is, would i be okay running 4.88's in my 8.8 until i can comfortably afford to do a 975 swap? or am i better off just doing the swap right now? thanks in advance!!
Old May 20, 2010 | 09:31 AM
FX41's Avatar
In your situation, I would rebuild it as cheap as possible, which would probably be OEM parts.
Old May 20, 2010 | 09:33 AM
thejake1989's Avatar
your 8.8 should be fine with 4.88's
Old May 20, 2010 | 12:55 PM
b2therad's Avatar
^exactly. I doubt you will have any problems from the 8.8 unless you have a supercharger and like to put your foot in it.
Old May 20, 2010 | 01:07 PM
Toyz's Avatar
Gears for $300?
And if you do swap to 9.75, they can be had for far less than $500.
I just sold a 9.75 with 3.55 LS and full disc brakes with only 10k miles for $300 a few months back.
Why do you want 4:88 gears?
Old May 20, 2010 | 02:28 PM
mluna84's Avatar
Originally Posted by Toyz
Gears for $300?
The few places that I have called so far have told me $500-$600 for the rear end...with gears and labor for the install, I'm estimating it do be around $800...I still need to shop around a little bit more...
I'm running 37's on my truck, thats why I want to go with 4.88's...the 4.56's that are in it right now were perfect for the 35's I was running prior to getting the 37's...
Old May 20, 2010 | 03:41 PM
kingbrian's Avatar
well ill buy your rear end tonight if ya wanna sell it!
Old May 20, 2010 | 11:54 PM
cleancrew's Avatar
well parts wont cost you $800, i rebuilt my 8.8 rear in my mustang with 4.10s and spent no were near close to that. if 1500 hpwr mustangs can take the abuse with rear end so will a truck.
Old May 21, 2010 | 12:28 AM
b2therad's Avatar
Gunna have to throw a BS flag on that one. No way you have a 8.8 on a 1500 horsepower mustang, and if you did it wouldnt last. A 5.4 with a supercharger will blow a 8.8 to pieces if you put your foot in it. Just ask klitch, because he has gone through a bunch of them. I would imagine that a 1500 horse power mustang would disintegrate a 8.8.
Old May 21, 2010 | 12:51 AM
GATOR CREW's Avatar
2009 F150online Truck of the Year
I'm Supercharged and I'm running an 8.8 with 4.56's....no problems here....I think you should be fine with 4.88's
Old May 21, 2010 | 01:15 PM
Expyon37s's Avatar
my old 97 f150 with the 8.8 had 4.88s and a detroit locker turning 38x15.5s and the truck is going on 4 years now and the guy that owns it now beats the hell out of her and no problems... so IMO 4.88 will be fine in a 8.8
Old May 21, 2010 | 04:30 PM
Dnasty777's Avatar
I thought all screws came with 9.75"?
Old May 23, 2010 | 12:37 AM
my64falcon's Avatar
You could put 1500 horsepower through an 8.8 without destroying it, but DEFINITELY not for under $800. To handle that it would involve welded tubes, 33 spline axles, c-clip eliminators, high dollar spool and gears, ect, ect. all high dollar stuff. I am looking to maybe do a 9.75 swap eventually too. I wanna swap to 4.10s to help with towing on 33s. I may stick with the 8.8 unless I found a good deal on a 9.75
Old May 23, 2010 | 01:00 AM
bigdad8214's Avatar
What he said, unles your gonna tow or somthing like that..... but just big tires, ur fine
Old May 23, 2010 | 11:06 AM
GATOR CREW's Avatar
mmmm not sure, but mine has an 8.8....maybe the 4x4 crews do
