Spindle lift. What all needs to be done?
Old May 4, 2010 | 11:06 PM
hagen1521's Avatar
With a spindle lift, do i need to get the cam kit or whatever, or would it be fine to just put the spindle on and a rear block?
What are the best kind of spindles?
Old May 4, 2010 | 11:10 PM
b2therad's Avatar
Either fabtech or doestch spindles. You dont need anything other than the spindles. You will need to get a grinder and grind down the inside of the lower control arm so that the spindles do not rub on them. Thats about it.
thejake1989's Avatar
you gonna do lift coils also? might as well do spindles blocks and lift coils with camber bolts also. talk to lightning expo hes selling his. and most people get doestch or spintech unless you want to spend 750 on the fabtech ones for just the spindles
Old May 5, 2010 | 11:53 AM
wandell's Avatar
I agree. If you decide to add coilspring spacers or lift springs with the spincles I'd go ahead and get camber bolts also.
Old May 5, 2010 | 12:33 PM
trailhunterf150's Avatar
i would recomend fabtech spindles, they are a little more expensive but i think well worth the money. plus with the other guys i couldnt find a 3.5" spindle i could only find 3". but it all depends on how much you wanna spend and what hight you want.
Old May 5, 2010 | 12:37 PM
http://www.doetsch-shocks.com/9.asp
just call them up
Old May 5, 2010 | 12:38 PM
doug435's Avatar
the reason that fab tech is 3.5 is because they move the mount on the side of the lower control arm ... but that also means that had to move the stud out .5 of a inch so your front wheels stick out .5 inch on each side personally i like it but some dont ...
Old May 5, 2010 | 12:40 PM
b2therad's Avatar
Fabtech makes 3" spindles. Doestch is the only one that makes 3.5" spindles, and they only work on non 4 wheel ABS models(or front wheel ABS).
Old May 5, 2010 | 12:49 PM
doug435's Avatar
^^ sorry man that's not true... they sell it in their 7.5 kit i am also running them on my truck
http://www.fabtechmotorsports.com/pd...60-81_ford.pdf
Old May 5, 2010 | 01:14 PM
b2therad's Avatar
I stand corrected, but holy crap that link took forever to load.
Oh, and if you call doestch OP make sure you dont order steering stabilizers from them. They don't come with brackets, and the brackets they want you to buy cost $70.
Old May 5, 2010 | 02:53 PM
hagen1521's Avatar
the Rough Country 3" lift kit for the 97-03 2WD Ford F150 truck includes CNC machined front steering knuckles with a rear block kit and hydro shocks. Shock boots not included.
Idk what a CNC machined front steering knuckles are?
that the only hesitation i have with this kit.
Old May 5, 2010 | 04:47 PM
campo141's Avatar
These are also 3.5" spindles.
http://cgi.ebay.com/ebaymotors/97-03...Q5fAccessories
http://cgi.ebay.com/ebaymotors/5-5-L...Q5fAccessories
Old May 5, 2010 | 05:20 PM
doug435's Avatar
PLEASE PLEASE PLEASE DO NOT BUY THIS BRAND !!!!!! THEY WILL BREAK PERSONAL EXPERIENCE ..... and have heard may of the same story
as for second link those are 4x4 .... come on now...
Old May 5, 2010 | 06:04 PM
campo141's Avatar
Never had personal experience with them.. And the second link is for 2WD only!!!
Old May 5, 2010 | 06:13 PM
doug435's Avatar
can tell you the pic on the second link is a 4x4 spindle ... lol never the less that brand blows the big one...
