thermostat and oil pressure guage problems...
Old Apr 14, 2010 | 07:18 PM
sfyarborough's Avatar
Hey guys i have a 97 f150 with an 05 5.4l motor and ive recently ran into a problem... whenever i crank up my truck my oil pressure gauge is fine and my thermostat is all the way down, but after idling for 3 to 5 minutes the thermostat will shoot up to hot and the oil pressure gauge will drop simultaneously.. But if i hook up and after market thermostat my oil pressure gauge is fine but my computer thinks my truck is still cold so im not getting all of my motor... Someone plz help me..
Old Apr 14, 2010 | 07:26 PM
1997 has two temp sensors, one goes to the gauge in the cluster, the other goes to the PCM.
Old Apr 14, 2010 | 07:36 PM
so your saying if i disconnected the temp sensor from the block it wouldnt change anything with the computer?
Old Apr 14, 2010 | 09:16 PM
well did you use your old intake manifold when you did the swap? If not then you may not have two temp sensors any more
Old Apr 14, 2010 | 10:33 PM
i believe i did i didn't do the swap i had someone do it for me... so what would be ur advice on fixing this?
Old Apr 14, 2010 | 10:49 PM
have you hooked up aftermarket (test) oil and water gauges? If everything is normal on the engine then maybe you're cluster?
not really sure where to start with this. I assume you're running the 2005 5.4 PCM then? original cluster? 2005 cluster?
Old Apr 16, 2010 | 12:50 AM
ive hooked up an aftermarket water gauge and my oil pressure is fine then its just when i hook up the stock one they act all crazy after a few minutes of idling...
