Transmission and brake help!!!
Old Apr 12, 2010 | 08:07 AM
garnbill's Avatar
fixed the transmission
1997 ford f-150 4x4 4.6 l
1st the 4x4 manual shifter on the floor will not budge the 4 wheel drive has worked in the past but hasnt been used in 2 or 3 years seems like its jammed or something
2nd off my brakes, well when i go to brake my brakes feel really soft and they pulsate while pressing them all the way down and its hard to stop unless i really slam them on the abs light is on also and ideas?
Old Apr 12, 2010 | 10:13 AM
fordracing200's Avatar
the linkage usually ceases up on the T-case lever, get under there and spray it with some pb blaster or something, then pull with all your might, worse case scenario you break it and have to buy a new linkage..ABS light is just a sensor, brakes sound like warped rotors and shot pads, have you inspected them?
Old Apr 12, 2010 | 10:32 AM
garnbill's Avatar
yes inspected the brake pads and rotors they are new the pulsating isnt a vibrating like warped rotors the brake are really squishy and soft and the pulsating feels like air in them i will bleed them and try that to see if it works
Old Apr 12, 2010 | 10:30 PM
f150fella08's Avatar
yea bleed them and see what it feels like..thats probably what it is
