Pinion seal flange nut
Old Apr 12, 2010 | 03:20 AM
TIDOSFX4's Avatar
I had a leaky pinion seal and I know everyone says do not over tighten the flange nut, and guess what I did! but by only maybe an 1/8th of a turn my question is if I back it off just that much is everything screwed up??
Old Apr 12, 2010 | 08:36 AM
illness95's Avatar
U know for sure u over tightened it ?
Old Apr 12, 2010 | 11:20 AM
rednutbow's Avatar
have you cheacked the rotating force on the pinon?
I you overtightened it you nees to install a new crush sleve... which means dissasembling the whole rear end.
Old Apr 12, 2010 | 07:15 PM
TIDOSFX4's Avatar
So I drove to ford today and noticed a hum in the diff, which was the same sound on my toyota when I did not tighten the pinion nut enough. So hopefully that is true. I will be rechecking the inch-lbs on the pinion later, I also checked with Ford and according to them (they showed me the diagram) I do not have a crush sleeve my flange did not come with one. I got a new nut and will be redoing the torque hopefully that fixes the issue.
Old Apr 12, 2010 | 10:08 PM
rednutbow's Avatar
Well I hate to inform you that you do have a crush sleeve. I would never take my truck back to that dealer! The only proof I can come up with other than personal experience is this article...
http://www.fourwheeler.com/techartic...ild/index.html
"The 9.75 has had a few changes in its relatively short life, including larger axle bearings and shafts in '99 (from a 1.620-inch inner diameter to 1.705 inches), a larger outer pinion bearing (increased from 1.31 x 2.68 inches to 1.31 x 3.00 inches), and the pinion was altered for a longer crush sleeve."
Old Apr 12, 2010 | 10:19 PM
TIDOSFX4's Avatar
Is the crush sleeve internal then?? The reason I ask was that the diagram he showed (the parts break down) showed a crush sleeve on the flange itself, however my axle 905A did not come with that part. Where would the sleeve be?? Just dont want to mess anything up!! And I have no choice on the dealer as it is the only one here!! lol
Old Apr 12, 2010 | 10:36 PM
rednutbow's Avatar
yes its on the back side of the pinon baring. From what I remember its the last thing on the pinon, so it would be right next to the flange but on the inside of the diff.
Old Apr 12, 2010 | 10:44 PM
TIDOSFX4's Avatar
This is the diagram that he showed me, is 4859 the sleeve? as i put in that text box he informed me that it was not on mine just the flange was. Just want to ensure I understand you right so that I can go in there and cuss them out for not giving me the right info. Thanks red I really appreciate it.
Old Apr 12, 2010 | 10:52 PM
rednutbow's Avatar
yeah that is a crush sleeve. but that parts diagram is for a 8.8. but Im pretty sure it will be very similar. I tried searching for a 9.75 diagram but I couldn't find one.
Old Apr 12, 2010 | 10:55 PM
TIDOSFX4's Avatar
Ok cool I will pull it off again and see what I get, Thanks again red yeah I looked all over for a 9.75 diagram too and no luck. The part #'s were the same thats why I chose that pic.
Old Apr 12, 2010 | 11:07 PM
rednutbow's Avatar
your welcome
