How hard will this be
Old Apr 8, 2010 | 10:51 PM
never ending's Avatar
I have a 97 scab and i want to know if it is possible and how hard it would be to put the stock ford step bars on my truck. i just truned the t-bars a few turns and put in 285's and the gf is 5'1" and hates getting into my truck.
thanks in advance.
Old Apr 8, 2010 | 10:56 PM
fordracing200's Avatar
pretty easy.....its only a few bolts..
Old Apr 8, 2010 | 11:04 PM
illness95's Avatar
EXTREMELY difficult...its gonna take sooo long and be the biggest pain in the ***..i highly recommend that you do not attempt this on your own...
jk i have no idea.. but they look easy..
Old Apr 8, 2010 | 11:18 PM
lol mine has westin's, they were new a few months ago, it was only two brackets, like 4 bolts total I believe. OEM ford ones use tons of little bolts and small clips that clip onto the rocker....they sort of suck.
Old Apr 8, 2010 | 11:20 PM
thats what i thought. they cant be that hard but i thought i would ask to see if someone on here has done it or not.
thanks for the help
Old Apr 8, 2010 | 11:28 PM
minimonster17's Avatar
having a second person handy makes it easier to mount the step bars, but i have dismounted/remounted a set by myself before.
Old Apr 8, 2010 | 11:48 PM
illness95's Avatar
i was under my dads supercrew the other day and i think there is maybe 2 bolts at each end of the step bar.. or maybe 4, either way they look simple..
Old Apr 9, 2010 | 10:11 AM
wandell's Avatar
I agree.
Old Apr 9, 2010 | 11:12 AM
FlashmasterK's Avatar
Totally wicked easy. Westin for the win
Old Apr 9, 2010 | 11:25 AM
ChrisT's Avatar
I'll throw in another vote for westin, totally easy to isntall. Mine have held up great for the 7+ years I've had em installed. They've also saved my paint on quite a few occasions from large on\off road debris.
Old Apr 9, 2010 | 11:50 AM
fordf150farmer's Avatar
what kind of shape are your rockers in? if you get some that mount to the rockers make damn sure they are in good enough shape to hold the wieght of a person. i cant imagine how bad it would suck to step on one and then it break off. i dont know how westin mounts, but i would look for something frame mounted if possible.
Old Apr 9, 2010 | 12:28 PM
ucfperspicere's Avatar
I like the frame-mount idea. I was thinking about replacing my stock step tubes 'cause they're getting a little rusty (surface rust only). My half-baked plan was to use blank ¼" steel plates to extend the aftermarket mounts back to the frame. Any thoughts?
I'll probably end up just sanding and refinishing the ones that are already on there, but we'll see.
Old Apr 9, 2010 | 12:39 PM
Scratch that. I looked up the Westin Signature Series and saw their instructions at AutoAnything.com. Their mounting system of sandwiching the rocker panel and bracing further back seems pretty stout.
Don't know what brand I'd seen the other day, but their system looked a little weak and hair-brained, and required lots of drilling into body panels.
Old Apr 9, 2010 | 12:41 PM
A good set will require NO drilling and mount to the frame
Old Apr 9, 2010 | 02:53 PM
I've never seen ones that mount to the frame. You have a brand name to go along with that claim?
