weird noise...much money spent no fix yet any advice?
Old Apr 8, 2010 | 10:55 AM
formuladriver01's Avatar
Every time I am at a stop and mash on the gas there is a thumping noise and I feel the thumping or pounding coming from around the t-case trans area. I replaced the drive shaft and u-joints due to other problems. I have replaced the the trans mount. I cant think of what else it could be besides maybe motor mounts. Is there a cross member for the t-case that went missing after I had the lift installed?I dont know what else to do. Can anyone give any advice? Thank you all.
Old Apr 8, 2010 | 02:49 PM
str8t six's Avatar
What kind of lift do you have? Did it star happening right after the lift was installed?
Old Apr 8, 2010 | 03:07 PM
westtnfx4's Avatar
Maybe a loose exhaust? Bad hanger allowing it to bump something underneath?
Old Apr 8, 2010 | 03:12 PM
Veteran: Army
did you stretch the chain inside the transfer case????
Old Apr 8, 2010 | 03:22 PM
Well I found the problem...the motor mounts are bad. I had a friend place the truck in gear and hold the brake and mash the gas and both mounts moved about an inch! I have reason to believe this is due to the way had to pull my friends tacoma out of the mud several times. Thanks to everyone who gave advice and I hope everyone has a great day!
Old Apr 8, 2010 | 03:40 PM
str8t six's Avatar
How were you pulling him out? He must have really been buried!
Old Apr 8, 2010 | 03:48 PM
I would leave slack in the tow rope and mash the gas in first gear 4low and "yank" him out haha.
Old Apr 8, 2010 | 05:29 PM
str8t six's Avatar
That's how I do it. Bad luck I guess haha
