'00 2wd Leveling Kit Install
Old Apr 6, 2010 | 03:49 PM
jtwoodall's Avatar
From what i've read and what a few have told me is that a 2.5" leveling kit will require new control arms.. and that a 1.5" will not.
If this is the case, then I'm going to buy the Daystar 1.5" leveling kit for ~$40 and do the install myself. With the 1.5" level I should be able to run 285/70/16's which is roughly a 31.7" tire.To be able to run a 33" 285/75/16 I would need a 2.5" leveling kit. These are according to daystar.
Question 1: Can I run 285/70/16's with a 1.5" leveling kit?
2: Do I actually need new control arms for a 2.5" kit?
3: I'm going to buy a Ranch Hand grille guard this summer and they weight in at just over a 100lbs, if I had to get new control arms to compensate for the lift, would this extra weight drop it down enough in the front to get rid of the need for new control arms?
If all goes well this install would take place within the next 2 weeks in my buddys garage as my garage is a dorm parking lot. I know that I would need a coil compressor, but are there any other special tools needed?
Old Apr 6, 2010 | 04:06 PM
madmaxwell87's Avatar
anything over 2"s of spring lift requires new upper control arms because it pushes them too far out of alignment to be put back to stock specs and therefore bad wear and suspension and tires. This will change a little with the extra weight up front but I can pretty much guarantee that it will not be enough to not dictate new control arms.
I have never seen a 285/70/16- there are 285/70/17s though. If you go with the 1.5" spacer and stock wheels you can run 285/75/16s with minimal rubbing if any at all.
However the coil spacers settle over time so what looks level when you first install it will settle to about a 1/2" lower in the front (done it with both trucks I've installed them on) plus with the weight of the bumper you might want to look into a true set of 2" lift springs (stiffer than stock from what I hear so will be able to handle the weight better) or a lift spindle to get 3.5"s of lift.
You don’t need anything special besides metric sockets, jack, jackstand, spring compressor(not needed but makes it safer, just lower the jack when its on the lower control arm slowly to let off the spring pressure however it would make re-installation easier.) A ball joint separator is also needed. Youll need bearing grease to repack the bearings, a cotter pin, probably a breaker bar and tons of WD-40 or Pb blaster which should be sprayed on the night before
Do yourself a favor and get a Chilton’s or Haynes manual
Old Apr 6, 2010 | 04:22 PM
jtwoodall's Avatar
When the coil spacers settle and I lost that .5" will it affect my 285's any?
Old Apr 6, 2010 | 04:40 PM
I only ran 265/75/16's(32") on aftermarket wheels when i had just the coil spacer and i never had a problem and it looked good. There are other guys running stock wheels,285's and just coil spacers so hopefully theyll chime in. I think there might be slight rubbing on the control arm at full lock but Im not sure.
Old Apr 6, 2010 | 06:12 PM
alex7191's Avatar
I just used a floor jack under the lower arm (carefully and slowly) and didnt need a spring compressor. The coil didnt even act like it was going to pop out on me. You'll also for sure need a big ol' hammer to whack the spindle to get the upper balljoint out of it. A small sledge would be best. Breaker bar and PB makes it easier too
Old May 18, 2010 | 07:08 PM
Alex_4.2L's Avatar
Im runnin 265/75/16s right now without any lift on stock suspension and no rubbing whatsoever
Old May 18, 2010 | 11:00 PM
MmmBuckles's Avatar
you do not need a ball joint separator. i did mine with a jack, jack stands, and a socket set. didnt need a spring compressor either.
Old May 19, 2010 | 08:55 AM
thejake1989's Avatar
might be best to do 2" coils and run the 285/75/16's and the install is very very simple and theres ppl in houston that can help out also
Old May 19, 2010 | 11:37 AM
mud boy's Avatar
IMO i coil spring compressor makes the job 10 times easier. Dont use a tie rod seperator unless your planning on replacing the tie rods because i made that mistake.
WD40 and a small sledge are very helpful too!!
Old May 19, 2010 | 12:02 PM
pitman arm puller helps breaking the upper balljoints seat in the spindle but the spacer can be put in in like 2 hrs. (did it to my sisters rcab over winter break)
Old May 20, 2010 | 06:33 PM
BlueOval_Man's Avatar
I got coils, they run just fine. You might want to look into new shocks.
Old May 20, 2010 | 08:28 PM
mud boy's Avatar
x2 defently get new shocks
Old May 20, 2010 | 09:24 PM
Just as an FYi I got Procomp RoughCountry shocks for 0-2 inches of lift and mine still over extend, which is a bitch. Makes speed bumps horrible plus bridges so you may want to get the ones taylored to 4 inches of lift.
Old May 20, 2010 | 09:30 PM
Got some pics:
Truck Picture Leveled
Shows the crossmember, not level anymore
My Lift springs, as you can see UCA angles are off.
Old May 20, 2010 | 10:49 PM
alex7191's Avatar
i got rough country shocks for 2 inch lift and mine arent over extended
