98 f150 i need help
Old Mar 23, 2010 | 04:48 PM
whitaker83's Avatar
98 f150 i need help
hi i have 98 f150 4.6 4x4 and it has really started running like crap lately it didnt really run that great when i bought it but it is worse now it has a bad sputtering/hesitation problem real bad going up hills i recently changed my plugs and wires although i did not use motorcraft i also changed fuel filter and i use injector cleaner all the time i did recently clean my maf and it seemed to help it but still isnt right im thinking i might have a coil problem just not sure if any one has any ideas that could possibly help me that would be great thanks
Old Mar 23, 2010 | 05:23 PM
f150fella08's Avatar
change them again, and use motorcraft this time...everything you change you should use motorcraft.
do you have a check engine light?
Old Mar 23, 2010 | 05:50 PM
whitaker83's Avatar
i have no cel on but i will try the motorcraft plugs
make SURE no wires are crossed
Old Mar 23, 2010 | 08:55 PM
whitaker83's Avatar
got any more ideas on what it may be
Old Mar 23, 2010 | 10:18 PM
could be a coil....yours has 2 coils right?
Old Mar 23, 2010 | 11:01 PM
whitaker83's Avatar
yeah it does have 2 im sure my wires are not crossed i done the plug change my self and i was carefull to not mix the order up this might be a dumb question but how can u check for a bad coil with out taking it to a shop and could bad cats have any thing to do with it thanks for ur help
Old Mar 23, 2010 | 11:09 PM
cats, they make a sound like theres marbles bouncing around, or they will glow red
coil-use a extra spark plug, gap it right, and plug it into a spark plug wire and place it on your upper intake. when you turn the car over (dont start it) the spark should be blue, NOT WHITE, if its white, the coil or distributor is bad, if the spark is blue, then the coil is still good, the blue spark is much hotter, thats why i say it must be blue
how i was told to test them.
Old Mar 23, 2010 | 11:17 PM
whitaker83's Avatar
ok i will give that a shot thanks
Old Mar 24, 2010 | 10:19 PM
whitaker83's Avatar
i checked my coils the way u said to and they both seem to be ok the spark was not white it was a purple blue im gonna change the plugs again this weekend and use motorcraft this time maybe that will help i hope im not gonna give up
Old Mar 24, 2010 | 11:36 PM
damn man IDK then.....
Old Mar 25, 2010 | 03:13 AM
Are you using a small amount of dielectric grease inside the wire boots? What brand of wires did you use?
