Oil Filter Relocator: where to find reasonable replacement
After much playing around, I managed to stop the leak. One of the lines had a small hole in it in the hard section just before the oil filter. I cut the hard line and then put on a piece of hose to join the two ends. Works great!
And in doing some looking and checking with the spare 4.6 I have from a Crown Vic, it would be very very difficult to put the filter back on the block, if it would fit at all.
Now to fix the transmission line leak...
BTW the 2 coolers in front of the A/C condenser are transmission (the larger one) and power steering.
If there is an engine oil cooler it's probably a water/oil cooler (uses engine coolant).
Check to see if there are any other hoses going to the adaptor at the engine besides the ones going out to the filter.
My 91 F250 had one like that. There was a spacer of sorts between the filter mount and the block. The lower rad hose went to the spacer, then another short hose went to the waterpump from the spacer.
I haven't taken a real good look at my 97 to see if there are any other hoses going to the adaptor......
Aha, power steering cooler! Interesting...
When looking at the adapter thingy on the block there's the hoses coming out for the oil filter and the lower rad hose. I have the piece from a car-use 4.6 that would allow me to mount an oil filter horizontally on the block, but it would be rather difficult to get in there to do it...
I'm on my 3rd factory setup and have noticed a leak starting again in the lines near the filter - the factory lines suck horrendously on these units. If I can be without the vehicle for a bit I'll take the whole works off and get proper hydraulic fittings swaged on, not the cheap crimp crap that the factory setup comes with.
I know of folks who've had good luck with the Summit setup.
The dealer replacements are pricey, I was quoted around $200, but I read somewhere that you can get the hoses redone at a hydraulic shop for less.
I'd maybe see if I could snag a hose set at a yard, then take it to the hose guy and get the hoses redone.
If yours is not driveable, then just pull yours off and see about getting it rehosed.
I just checked out the Rockauto link further back in the thread, and the oil cooler hose listed for the 5.4 looks exactly like what is on my 4.6.
There is no listing on Rockauto for those lines on the 4.6....
I wish I'd seen that before I popped $250 at the dealer!
