What do i need for 3" Body lift??
Old Mar 10, 2010 | 09:48 AM
Halvar's Avatar
Hello from Austria!!
i want to buy a 3" body lift for my 97`f150 4,6L manual trans and manual 4 wheel drive
its on ebay Nr: 370344507474
for me its the cheapest way to get it to Austria
do i need a shift extension for both shifts (transfer case and transmission)
or dont
has anybody install this kind of lift to a f150 manual trans??
Halvar
Old Mar 10, 2010 | 12:21 PM
wandell's Avatar
If it's a kit made by Performance Accessories, it should include everything you need. I've installed 2 PA body lifts, but neither had a manual trans or transfer case.
Old Mar 10, 2010 | 01:03 PM
westtnfx4's Avatar
I've done the manual trans and transfer case and yes you have to have the shifter extensions for both...I had to buy them seperate because they did not come with the Performance Accesory kit...ask them to confirm that they do or don't come with the kit...GL
jk007's Avatar
x2 - I've installed 2 also, neither of them a stick. The PA kit should have everying you need, but I would double check.
Old Mar 10, 2010 | 01:07 PM
thejake1989's Avatar
You dont have to get the extension for the shifter but idk about the transfer case shifter. f you dont get it, it just means your shifter will be 3" shorter
Old Mar 10, 2010 | 01:28 PM
westtnfx4's Avatar
To do it the right way yes you need both extensions...
Old Mar 10, 2010 | 01:33 PM
the "right" way is very subjective. it works just fine without the shifter extension. my sister had one installed on her old truck from a reputable shop in houston and they didnt extend it (why idk) but its not a necessay mod such as the bumpers or gas filler tube extension
Old Mar 10, 2010 | 01:34 PM
cotedog03's Avatar
I'm pretty sure it comes with an extension for the tcase shifter, but it must be welded on. Could be wrong though, been a while since I looked at the instructions.
Old Mar 10, 2010 | 01:38 PM
westtnfx4's Avatar
Yes I think your right (T case shifter included) cause I had order the Tranny shifter extension and it was high...it was machined from Alum.
Old Mar 10, 2010 | 01:39 PM
b2therad's Avatar
It does have all the extensions you need, however, they require welding. They came with my PA body lift kit.
Old Mar 10, 2010 | 02:24 PM
Halvar's Avatar
thanks for the fast anwers
i will take it and if its not included i will built one of my own
Old Mar 10, 2010 | 04:36 PM
foreman400x's Avatar
on those extensions are they aluminum or steel
Old Mar 10, 2010 | 11:28 PM
bigun72's Avatar
Mine come with the t-case extension , but it did not come with the trans shifter extension , so i didnt fool with it...... and as Jake said you dont have to do the filler neck extension , you can just loosen your hose and slide it down a little and tightin it back up.
Old Mar 11, 2010 | 12:00 PM
OuTkAsT-F150's Avatar
My PA kit came with both but I didn't install the xfer case extension, it's just sits lower but works just the same.
