2 solenoids on 99 F150??
Yea, when you order a starter relay they call it a solenoid now lol. Not sure why, in the old days it was a relay and labeled that way. The starter solenoid piggybacked the starter in most cases.
These trucks have more than two solenoids, -I think of 5 of hand lol.
The "Bendix" is not the solenoid. The Bendix drive is the assembly inside the starter that engages the teeth on the flywheel and spins. The solenoid operates the Bendix.
The relay receives a low amperage connection from the ignition switch, that activates an electromagnet that makes contact for a high amperage wire to the starter. When the starter starts to spin, the centrifical force of the motor forces the starter drive gear into the ring gear, and starts spinning the engine.
