Oil pressure sending unit?
oil pressure switch
Alright folks, I went ahead and picked up a new pressure switch (only $6 dollars, and wouldnt hurt to replace it anyways).... and so far it has cleared my problem. That thing is almost impossible to get to. I will find out if its cleared for sure when I run to town later (20 mile drive). Thanks for the input guys.
-Matt
-Matt
Dan
Well, if your referring to the thread sealer -
http://www.frontiernet.net/~slray/04...s/Permatex.JPG
as of last night my truck started doing the erratic sweeping of the gauge.. the gauge would jsut drop down and as soon as the light came on it would jump back up to normal.. it did it 3 times this morning.. truck still runs perfect with no knocks or anything.. im assuming its the sending unit just like what was described in this thread...
@ mcolford...please message me a little more about replacing the switch. I have the same issue, at cold starts and especially below 50 degrees until it warms up. Not sure how worried I should be and this sounds like a much better idea than "shotgunning" expensive parts like a sending unit.
Thanks a TON!
R/Mike
Thanks a TON!
R/Mike
Give me a little bit and I can snap a picture. On the 4.6L, it is on the drivers side, I accessed mine thru the wheel well. IDK about part numbers, I just went to the parts store, told them what I wanted, and they got it for me.
As far as it being common, like one of the guys said already, it has a plastic core, which gets heated and cooled a billion times, so yeah its gonna wear out in time. Im not trying to sounds like a smarta$$, just sayin its kinda common to happen.
NAPA part number: ECH OP6218
-Matt
-Matt
