Brake pedal to the floor
Old Feb 22, 2010 | 05:40 PM
bbarber275's Avatar
So if all else fails drive the truck and jam the brakes on. LOL glad you fixed it
Old Feb 24, 2010 | 02:46 PM
j-man5.0's Avatar
Any updates from the op?
Old Feb 26, 2010 | 03:19 AM
willys5555's Avatar
i know another guy on here with a 97 and his brakes sucked also...mine did also till i got the new rear axle with disk brakes...now it stops like a champ! if you have no pressure then you got a problem, but with my experience, all of these trucks seem to have the brake pedal to the floor problem. lol
Old Mar 5, 2010 | 10:06 PM
ScooterL's Avatar
I would love to swap my rear drum axle for a disk, did you go used? did you have to replace any other components? I have a 97, do you know which years are a simple drop in instalation?
Old Mar 6, 2010 | 12:04 AM
whackemnstackem's Avatar
97-03 are all the same. you should be able to do a pretty simple swap. go by yer local junkyard you might be able to find one for roun $400ish. gotta make sure the differential size is the same (probaly a 8.8) your gonna have to run some brake lines for the calipers but they are good axles. stop real good
Old Mar 10, 2010 | 01:21 PM
TEMY's Avatar
I havent use this truck for a while becaus of the brake problem and this morning i started it and the brakes all of a sudden are working fine and the pedal dont go to the floor. Maybe the cold weather help it because i dont have any explanation for the probelm or the solution.
Thanks for sll your help.
Old Mar 11, 2010 | 01:57 PM
Brake pedal to the floor without a visible fluid leak and a full reservoir almost has to be a master cylinder with an internal leak.
Old Mar 11, 2010 | 02:39 PM
TEMY's Avatar
Like i said replaced the MC twice with a new one and didnt help. Anyway the problem went away by itself.
Old Mar 15, 2010 | 01:42 PM
j-man5.0's Avatar
Wierd aint it? My truck is still fine. I would imagine we both had the same problem whatever it was lol.
