Help wireing rear slider window
Ok i just started on my back window and he was right it does slide to the driver side not down. I just touched the yellow and red wires to the pos and neg wires going to my subs amp and it moved and i touched them opposite and it moved back the other way. So what i think im gona do is just run the power from my amp and put an inline fuse between the amp and the switch. Not sure what fuse to use. I have a 10 20 and a 30 amp fuse. Guess ill start with 10 and if it blows step it up one more.
Ill post a vid as soon as i finish. Should be like an hour or so.
Well i got it all wired at it works. But now there's another problem. When i open it it binds up and clicks a lil less then halfway but if you help it along a lil it will go. It closes just fine tho. So no video yet haha... not sure what the problem is i pulled the back seat off and looked at the slider its a C. R lawrance power slider.
