axle code
Old Jan 26, 2010 | 01:56 PM
sully853's Avatar
axle code
The axle code for my 2000 f150 4x4 extended cab is 27 from the little research ive done this corisponds to an f250 axle can anyone help my out im trying to figure out what gears i have
Old Jan 26, 2010 | 02:20 PM
BXK109's Avatar
Axle code 27 — 3.31, non-limited slip
Old Jan 26, 2010 | 02:54 PM
There is a list in the Articles and How To section along with everything else to decode the VIN.
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
F-250:
27 – 3.31 Non-LS
26 – 3.73 Non-LS
Ranger:
84 – 3.45 Non-LS
86 – 3.73 Non-LS
87 – 4.10 Non-LS
89 – 4.56 Non-LS
F6 – 3.73 LS
F7 – 4.10 LS
92 – 3.08 Non-LS
R5 – 3.55 LS
91 – 3.27 Non-LS
96 – 3.73 Non-LS
R6 – 3.73 LS
Old Jan 26, 2010 | 04:29 PM
sully853's Avatar
thanks for the help guys but since mine is 27 does that mean i have f250 axles or whats the deal?
Old Jan 26, 2010 | 04:35 PM
Have no idea, but do you have 7 lug wheels?
Old Jan 26, 2010 | 04:46 PM
kingfish51's Avatar
No, they use the same codes for both. Probably shouldn't be listed as 250 or 150. The 3.31 certainly would not be on a high GVW truck. On the 8200lb GVW, it would have a 4.10, which isn't listed. That does have the 7 lug.
Old Jan 26, 2010 | 10:33 PM
Dnasty777's Avatar
Is the H9 a 9"? Sorry for the threadjack.
Old Jan 27, 2010 | 07:40 AM
kingfish51's Avatar
No, Ford no longer uses a 9" rear. It is just the code for a 3.55 limited slip. It could be either an 8.8" or a 9.75" axles.
