My engine is Ruined
honestly with as sensitive as those COPs are made out to be i wouldnt spray anything on them.. i probably wouldnt spray wd40 on any electrical components.. regardless of if it hurts it or not.. i wouldnt risk it..
Read the can.
Absolutly "Do Not" use WD-40 on computer, electrical or mechanical parts.
If you disagree, - hit your wires/elec system with it, but get it on video for all to enjoy.
_________
Use a Automotive Silicon and/or a Di-electric (none mechanical/moving)
So - what's left? Private parts?
Maybe you should read dat can again ( got the right can, not the Yak **** lol?) - here's a partial list straight from their website:
I also meggared a puddle of it just now - got an infinite impedance reading .... wow - what a great conductor ! Not.
Drives Out Moisture
58 uses found.
•Drives moisture from moving garden tools to help prevent corrosion
•Drives moisture from door sill plate
•Prevents moisture damage on cable TV field strength meters
•Drives moisture from tire air nozzles after washing
•Drives out moisture from trunk locks
•Removes roof mastics from tools
•Displaces moisture from spark plug wires
•Displaces moisture from car wiring
•Drives moisture out of trunk locks
•Drives moisture from DC auto batteries
•Drives moisture from electrical wiring in cars
•Drives moisture from front struts
•Drives moisture from convertible top hinges
•Drives moisture from flooded engine
•Drives out moisture from flashlights
•Displaces moisture from submerged cellular phones
•Drives moisture from outdoor latches
•Drives moisture from moving parts of electric jewelry boxes after washing
•Drives moisture from home wiring
•Drives moisture from electrical contacts on weed eater
•Drives moisture from wheel bearings in shower door wheels
•Drives moisture away from pushbuttons that can become oxidized
•Helps clean bilge areas
•Spray on electrical panel boxes to drive out moisture
•Drives moisture out of shovel handles
•Drives moisture from seismic cable connectors
•Drives moisture out of electric generators
•Drive moisture from bottom of leaky coffee pot
•Drives moisture from helicopter quadrants
•Drives moisture from radar gear
•Drives moisture from precision tools
•Drives moisture from heavy-duty drills
•Drives moisture from ignition coils•Drives moisture from ignition distributors
•Drives moisture from spark plugs on tanks
•Displaces moisture from electrical conduits
•Drives moisture from telephone wire connections in network interface box
•Removes hydraulic fluid from Lear jets
•Drives moisture from pocket watches
•Drives moisture from hearing aids and cleans battery compartment
•Drives moisture from antenna connectors
•Drives moisture from bird bath heaters
•Displaces moisture from guns after cleaning
•Drives moisture and mud from duck guns
•Spray on bottom of wet running shoes to drive out moisture
•Drives moisture from buckles on scuba diving belt
•Drives moisture from fishing waders after use
•Removes moisture between handle & shaft of golf irons
•Drives moisture from wet bicycle chains
•Drives moisture from fishing tackle
•Drives moisture from lifejacket turnbuckles
•Drives moisture from gyro compasses
•Drives moisture from bicycle gear shifting cables
•Drives moisture from bicycle bearings
•Drives moisture from moving parts of compound bows
•Drives moisture from boat trailer lights
•Drives out moisture from jet ski spark plugs
•Drives moisture from a boat's moving screws
Huh!
I just checked the WD40. I sprayed a puddle of it on a piece of plastic and checked it with my VOM, and there was infinite resistance.
But years ago I saw a guy pull a prank with WD40. He charged a condenser, and had this other guy hold it. Then he sprayed it with WD40 and it discharged in the guys hand. It was funny to those of us watching, but that guy flung the condenser across the room.
So what is up with that trick?
Huh!
Too bad they haven't reformulated Seafoam - same old uselees crap as it's always been ...
I guy charged a condenser and through it to me once. He said "Hey catch this". It was quite a shocking experience. I'd sure hate to get zapped with a tazer
A buddy of mine drove through a real flooded area once in his little car. The engine bogged, luckily in a parking lot. So he waded through the water and parked his car in a spot and the next day went back. We pulled the plugs and cranked the motor over, thus blowing out any possible water in there. Threw new plugs in and she fired right up. Might wanna try that if you think you waterlocked it. I'm sure this wouldn't work on a severe case...
Which just about covers everything ...
Drives Out Moisture
58 uses found.
Drives Out Moisture
58 uses found.
Like I said , lets see yuh do it. Better get a case of it for the ultimate
application. Maybe they'll throw in a hat, -there you go, you could be a regular Joe WD! That would be the coolest thing ever.
Wear that sucker while your doing your door to door thing, - attempting to sell some lost sole a set of Champion plugs. It might be your lucky hat.
Don't forget, take lots of pics for this website as you progress.
BTW- I heard you can apply a second coat much quicker if you do this KOER.
Regards
