windows
Old Jan 16, 2010 | 12:23 PM
PurttyGurl's Avatar
windows
How do i reset the power windows they are stuck down and won't roll up?
Old Jan 16, 2010 | 12:33 PM
jbrew's Avatar
Vehicle year? Model ?
There should be a book in the glove box that will direct you to the fuse related to your power windows.
If the fuse is okay and neither switch is functioning. Reboot your vehicle by disconnecting the battery for 20 minutes or so.
I had the same issue in a 98 model and to reboot, but check the fuse first.
Good Luck and welcome to the site. ( :
Old Jan 16, 2010 | 04:19 PM
PurttyGurl's Avatar
Ok thanks for your help
Old Jan 16, 2010 | 05:06 PM
c_ulater's Avatar
Welcome. Good luck with the windows.
Old Jan 21, 2010 | 09:39 PM
c_ulater's Avatar
Any luck with your windows?
Old Jan 22, 2010 | 12:29 PM
PurttyGurl's Avatar
No I haven't had any luck and no feedback so its sitting in the garage i can't drive anywhere cause of the rain and its a lil cold all of sudden. I tried to disconnect the battery and i checked all of fuses and the circuit breaker under the hood so someone is still gonna come and troubleshoot for me. If I have no luck i guess i will be letting the dealer get in my pockets. i took a look at you truck its very nice.
Old Jan 22, 2010 | 12:55 PM
jbrew's Avatar
Make sure you post back what the problem was. If all windows don't work, then it should be as you were already instructed. That book should direct you to what fuse/relay to check, -every one. Not sure what else it could be with both windows inoperable.
I'm not sure if this has anything to do with the windows working, but check the GEM fuse as well. Goofy things happen when that one goes lol. It's in that same book.
Old Jan 22, 2010 | 03:37 PM
maddoughboy's Avatar
Best thing to do with fuses is check them all since you might not think it is linked but it is. I have dealt with a car that the securtiy system got activated when a fuse blow that you would have never geussed would have effected it.
Old Jan 22, 2010 | 04:17 PM
jbrew's Avatar
Good Idea, this is true, you never know and it doesn't hurt, that's for sure
Old Feb 2, 2010 | 10:43 AM
PurttyGurl's Avatar
Windows
THANKS EVERYONE I HAVE BEEN AWAY BUT I WILL BE CHECKING ALL OF THE SUGGESTIONS TODAY I WILL LET YOU GUYS KNOW WHAT I FIND.. AGAIN THANKS FOR ALL YOUR HELP
