Main difference in the 97-98 to the 99+
Old Jan 11, 2010 | 10:52 PM
JNC995's Avatar
What are the main differences in those two models? I hear something about a different motor, but what all is different.
Main reason I ask is b/c there is a 97-98 for sale that has the 5.4 and a 5 speed. Been thinking about going to check it out, but the difference worries me.
Old Jan 11, 2010 | 10:57 PM
Halverso_99's Avatar
Off the top of my head...
Front end, Interior door panels, No PATS, No advanced computer, etc.
Old Jan 11, 2010 | 11:17 PM
JNC995's Avatar
Front end as in grill area, or front end suspension?
Whats the advanced computer do?
Old Jan 11, 2010 | 11:30 PM
Harper 184's Avatar
if im not mistaken the 97-98 are running a traditional coil and plug wires setup and 99 and newer are now coil packs on each plug. Im not sure what some of the other improvements were, but there was a lot of cosmetic changes, such as newer gauges with LCD odometer.
Old Jan 11, 2010 | 11:39 PM
illness95's Avatar
yupp.. front end being the grille and bumper
Old Jan 11, 2010 | 11:40 PM
illness95's Avatar
nvm
Old Jan 12, 2010 | 04:33 AM
Klitch's Avatar
front cosmetics, header panel, interior package on 97, 3 vs 4 dr, gauges and pats, torsions, intake and heads, 4.6 went to cop ignition. fuel rails changed (regulator not changeable 99+)... mostly minor, but the PI intake/heads is the motor difference for the most part
Edit: 6/96 (roughly, i may be wrong) is the cut off date for the old style header panel.
Old Jan 12, 2010 | 06:12 AM
deerhunter7979's Avatar
Finding a 5.4 manual 5 speed is rare indeed. Care to share where? Any other details.
Old Jan 12, 2010 | 07:08 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
...Main reason I ask is b/c there is a 97-98 for sale that has the 5.4 and a 5 speed...
Zero came from the factory with a 5 speed 5.4L.
Old Jan 12, 2010 | 07:12 AM
Veteran: Army
if it had a 5.4 it's been swapped in...
Old Jan 12, 2010 | 08:09 AM
Raoul's Avatar
25 Year Member
You need to look at the VIN and door jamb sticker to see what was swapped.
8th position of the VIN:
2 = 4.2L
6 or W = 4.6L
L = 5.4L
The door jamb has the Trans Code:
U or E = Auto
M = Manual
(There was never a Model Year where the VIN is 'L' and the Trans Code is 'M')
There is a member here (JMC) with a 5.4L/5 speed.
His conversion is in the tech articles forum.
Nearly all I have seen advertised are just dealer misprints where either the motor or trans was listed incorrectly.
Old Jan 12, 2010 | 08:16 AM
jbrew's Avatar
Oil filter location, those were the best years for that, you'll like it.
The only worry. Like any vehicle, has it been takin care of ?
Old Jan 12, 2010 | 09:38 AM
chrmar's Avatar
Are you sure on the header panel? In Raptor's swap thread, he indicates that the header panel is the same...
Old Jan 12, 2010 | 01:14 PM
Klitch's Avatar
my bad, 97's with build dates before 6/96 are different than later. thanks for reminding me!
Old Jan 12, 2010 | 03:08 PM
chrmar's Avatar
That's a relief. I want to swap to a HD/Lightning grille in my Expedition eventually and was worried I'd have to change the header! Build date 04/97
