I have $100 to spend
Old Dec 20, 2009 | 07:08 AM
Dinggus's Avatar
I have $100 to spend and I have no clue what to spend it on, should I get a K&N Air Filter or what?
Old Dec 20, 2009 | 07:47 AM
Veteran: Army
get a drop in filter and do the gotts mod
Veteran: Army
then change your oil and plugs
Old Dec 20, 2009 | 10:52 AM
sharpshooter109's Avatar
You could level it. That's $40 for the spacers, install the yourself(which is a piece of cake to do) and $60 to spend on the alignment.
If your interested in performance mods, I would suggest possibly getting an eBay intake and a quality filter to go on it.
I have no personal experience with k&n, but when I was reading about them, people were saying that they didn't fit good in the stock airbox so some air and dust could get around the filter. I have a s&b drop in filter and i don't have any complaints about it.
Old Dec 20, 2009 | 12:58 PM
FordGuy24's Avatar
I'm with tarajerame...get the filter and do the GOTTS mod
Old Dec 20, 2009 | 02:33 PM
Dinggus's Avatar
Okay, I have no access to parts to do the leveling, which I wish I could do. As for the filter and Gotts Mod, I can do that, just I don't have a dremel tool or sander.
Old Dec 20, 2009 | 02:39 PM
jethat's Avatar
I did the gotts mod with out the need for a sander. Get the smaller sewer pipe the thinner walled stuff. cost me under $6 for about 10 feet of the stuff. Fits right in the fender hole. Then just the 3 inch rubber sewer pipe connector that cost about $6 total $12 only tool you really need is a hacksaw and a flathead screw driver
Old Dec 20, 2009 | 02:43 PM
Dinggus's Avatar
Okay, and you got those at Home Depot? The only thing I'm afraid of is messing up and then my truck is torn apart.
Old Dec 20, 2009 | 02:51 PM
jethat's Avatar
Yep thats where I got it. You dont do anything to your truck that cant be reversed. Just take off the airfilter housing and remove the stock snorkel at the end. The thin pipe i'm talking about has a thin white coating and is black on the inside. it comes with a connector on one side so its different from the standard pipe. Much thinner wall. You'll know it when you see it. works great my truck has more power then ever but I've also done a whole bunch of other stuff to it in the last few weeks. Not sure how much that did for it. I have quite a bit more power then I did though. Sounds better to.
Old Dec 20, 2009 | 03:19 PM
Dinggus's Avatar
Okay, well I'll go to Home Depot and go buy what I need, and get that K&N air filter. Will definitely get back on if I need help.
Old Dec 20, 2009 | 03:21 PM
offroadn'98's Avatar
Gotts and K&N high flow filter
Old Dec 20, 2009 | 04:24 PM
Dinggus's Avatar
Is the 3 inch PVC pipe suppose to fit into the air filter assembly, or is the coupling just there to join the PVC pipe and air filter assembly together?
Old Dec 20, 2009 | 04:36 PM
Veteran: Army
read the "how to"
Old Dec 20, 2009 | 04:40 PM
shifty_85's Avatar
Gotts mod 10-15 bucks. drop in K&N 40 or so. thats around 50 bucks.
get an E-fan around here at junk yards its 30 bucks any set up you pull. i have a lincon mark 8 24" E-fan. the 2000+ crown vics have the big fan as well.
or you can take the remaing 50 and do plugs and oil change.
Old Dec 20, 2009 | 04:52 PM
you need a belt sander to do the gotts mod. at least if you do it the way i did it.
