trouble codes???
Old Dec 15, 2009 | 03:39 PM
kingbrian's Avatar
trouble codes???
a buddys got an 01 f150 and hes getting codes that my scanner isnt working with here they are.
p061F
21112
21041
i remember seeing these codes (not p061f) somewhere but i cant find them now. any help???
Old Dec 15, 2009 | 07:31 PM
projectSHO89's Avatar
Time for a new scanner.
Old Dec 15, 2009 | 11:30 PM
AZTriton's Avatar
Those are for the turn signal fluid.
Yeah, try a different scanner!
Old Dec 16, 2009 | 02:46 AM
kingbrian's Avatar
well the p code i know is a generic code and it has to do with the drive by wire crap. the other two are ford specific codes that one time long ago i had those codes as well but now i cant find it. i know the scanner is fine but we found the problem so we'll fix it and go from there.
Old Dec 16, 2009 | 03:13 AM
Bluegrass's Avatar
Use another reader or scanner.
The 01 doesnot have electronic throttle control if that it what you mean.
The large numbers you gave are not correct.
P0061 would be for the OX sensor heater circuit on bank 2.
Old Dec 16, 2009 | 03:36 AM
kingbrian's Avatar
p061f is the code, Internal Control Module Throttle Actuator Controller Performance... drive by wire was wrong terminology.
Old Dec 16, 2009 | 07:35 AM
NONE of those are valid fault codes for an 01 running factory PCM and programming.
Rescan with something else, ESPECIALLY if you used a tuner for your scan.
