Gas Cap Farts :)
Old Dec 8, 2009 | 08:32 PM
skunkcontrol's Avatar
Gas Cap Farts :)
I have had a High pressure fuel tank light for a month or so now and planned to buy a new cap but was not real concerned with it until I got the heater core replaced (Havent been driving)
But today while truck was Idling I noticed the fuel inlet with cap on basically burping or farting (what it sounds like)every minute or two..
Anyone ran into this or have any ideas?
and no I will not put Beano in my tank
Old Dec 9, 2009 | 12:46 AM
Rabbit_'s Avatar
My 97 F150 did the same thing, quite often actually. I never did find a fix for it.
Good luck.
Old Dec 9, 2009 | 12:51 AM
Good catch... I was going to go for the lame crack... you beat me too it
Old Dec 9, 2009 | 09:18 PM
Drexelsteve's Avatar
High pressure fuel tank light? never heard of it. If your fuel cap is burping you've got evap problems, either the vapor management valve or canister vent solenoid. I'm assuming the cel is on, codes would help
Old Dec 9, 2009 | 09:58 PM
Sorry Guys I have not read it recently until tonight, but the Code is PO453 Evap emission control system pressure sensor High.. And yes Drex it is the CEL light and my very last code, had just assumed it might be a Gas cap but now that i know its venting like that just wondered if anyone else had ran across it.. any help is appreciated.
Old Dec 10, 2009 | 04:34 AM
EBXGSXR's Avatar
i thought when the gas cap is loose or gasket is bad, the code that comes up is a small evap leak?
Old Dec 11, 2009 | 02:05 AM
Stephen87's Avatar
all I know is that when my truck was farting I just replaced the gas cap and all was well
Old Dec 11, 2009 | 11:11 PM
I replaced mine yesterday and it died and would not start back lol so tomm when it warms up I am diving in looking for a vent and the emission canister i guess..
Old Dec 12, 2009 | 12:04 AM
Paralyzer's Avatar
canister vent is most likely plugged, vent solinoid, canister, canister filter and hoses are all possible causes. A cap will not fix this. A cap is supposed to seal.
Old Dec 12, 2009 | 12:30 AM
kuruption's Avatar
Parents had this issue on the Merc Grand Marquis. Cap replacement didn't fix it. After about 2 years and 6 dealer visits, one of the mechanics actually heard the noise (it was quite intermittent). Ended up being the clogged solenoid as Paralyzer said. Supposedly a dangerous condition if it's not fixed as the intent is to allow the release of gas fumes out of the tank.
