heater help in blind door??
Old Nov 30, 2009 | 06:05 PM
morris150's Avatar
is there a way to open the blind door so the heat can flow with out taking the dash out of the truck? I have a 2000 F150XLT excab. No I dont hear the door open or close when I turn on the heat.
Morris
Old Nov 30, 2009 | 06:37 PM
MmmBuckles's Avatar
probably the blend door actuator. i believe its located under the center of the dash next to the floor board.
Old Nov 30, 2009 | 06:59 PM
morris150's Avatar
Yes sir I know that but I was told the only way to get to it is to remove the dash is there a short cut to get to it?
Morris
Old Dec 1, 2009 | 01:53 AM
supernova1021's Avatar
Morris.. Go to the HVAC forum. I posted a link to a site that sells a reinforced blend door and they have a short cut (literally) to get to the door. Hope it helps. I am probably going to go that route sometime before the spring as mine is stuck in the heat position so no need to worry about it right now.
