Spare tire help
Old Nov 22, 2009 | 11:20 PM
01redscrew's Avatar
Spare tire help
I've got a 2001 supercrew and I got a flat the other day, lowered the tire got it changed blah blah blah. Well today I went to put it back up and something went wrong and about 3 inches from being up alll the way things went bad and it wouldn't go either way. So not wanting to drive like this I took a cable cutters and cut the cable and figured on buying a new one. After I got the tire out I looked up there and on the inside the cable was all unbraided and knotted up in there so that is most likely the cause.
Anyway, I did a google search for 2001 f150 spare tire carrier and couldn't find anything that looked similar so I'm wondering what the heck they call that thing and if anyone knows a good place to order one?
Old Nov 22, 2009 | 11:30 PM
coobies5's Avatar
junkyard, they are easy to replace and rather cheap
Old Nov 23, 2009 | 08:09 PM
fordracing200's Avatar
mine's junk too...damn ny winters..
Old Nov 23, 2009 | 09:14 PM
01fordexpy's Avatar
I just replaced mine for the same reason, mine was 85 bucks from the dealer. Real easy to change.
Old Nov 23, 2009 | 09:35 PM
jgger's Avatar
They call it a winch, I think the whole name is spare tire winch. About 80 bucks at the stealer. I'd do the junk yard. Just make sure if you have a "key" on the old or new one, you can crank it up and down. You can just pop the lock out with a screw driver, then the regular jack handle works.
