starter?
Old Nov 16, 2009 | 10:42 PM
dads truck's Avatar
starter?
so some-one slashed two of the tires on my truck; so I found a set of lightning rims & tires for it (pics to come); but now it won't turn over; very recently replaced alt; belt/tensioner - battery is pretty recent (and seems to be lots of accessory power; it clicks once and thats it;
I think its the starter - tough to find on the 4.2; if its what I think it is you can't see it from above; and it sits passenger side just behind the lower A-arm?
anyhow, tapped and banged it best I could from below; and truck still no start. Any other thoughts on what the prob might be?
btw, there is a leak into the truck; but carpets up front seem dry and leak seems contained to under back seat of ext cab.
thx
Old Nov 17, 2009 | 01:19 PM
jethat's Avatar
My experiance has been that ford starters RARELY fail. Check your connections then try shorting the big post to the small post on the firewall relay/solenoid if it starts replace the solenoid. I've replaced several perfectly good starters.. Dont make the same mistake.
Old Nov 18, 2009 | 02:25 PM
The solenoid attached to the starter fails more often than the starter itself. Terminology - the component on the firewall or fenderwell is a relay, but also called a solenoid. There is also a real solenoid on the starter.
