A Quick brake Question?
Old Nov 10, 2009 | 06:58 PM
Layedout02's Avatar
ok i put new front brakes on at 65k now im at 73k, when i put them on i did not turn the rotor, now its time for rear ones, should i turn the back ones, and should i put new fronts on and turn the rotor
Old Nov 10, 2009 | 11:04 PM
f150fella08's Avatar
if they dont wobble when you hit the brakes, then i wouldnt turn them.
Old Nov 10, 2009 | 11:12 PM
I never turn them if there are no grooves on the surface.
Old Nov 11, 2009 | 07:14 PM
Layedout02's Avatar
Yea it dont need front brakes but they are groved real bad, im turning the back ones when i replace them
Old Nov 12, 2009 | 03:30 PM
maddoughboy's Avatar
You shold turn the rotors but go to a shop not a parts store. Unless your front are haveing issues then just run them as is tell you need new brakes.
Old Nov 14, 2009 | 04:02 PM
If you put new pads in with grooved rotors, you will need to replace the pads again if you turn or replace the rotors.
Old Nov 14, 2009 | 04:17 PM
i havent turned the rears on either of my trucks when i put pads on because its a solid rotor (non vented) so it doesnt really warp. Just make sure the rotor isnt heavily grooved.
