PRND21 pointer fix
Old Nov 3, 2009 | 01:04 AM
MmmBuckles's Avatar
Ethan i adjusted the one on my family's 1998 Windstar this evening, and its directly beyond the ignition switch, on the side of the column, just behind the dash fascia
gracias. im sure my gma will appreciate being able to know what gear she is in again
Old Nov 3, 2009 | 09:00 AM
I would imagine that the Explorer is more similar to the F150 being that both are RWD vs the FWD windstar
Old Nov 4, 2009 | 11:23 PM
JohnBoy88's Avatar
What about tightening the actual shifter itself?
I've noticed that my shifter seems loose. The indicator is fine and in the right position, but after i put it in drive, the shifter will wobble around loosely. Drives me nuts. Never used to do that. My brother's and my dad's are both tight and stay in place, and my brother's truck is older than mine...
Old Nov 4, 2009 | 11:47 PM
got me on that one, ill look it up, but i believe there is just a spring that you have that is stretched out
Old Nov 5, 2009 | 09:10 AM
WowGuyF150's Avatar
I can not get my pointer to move either way still. It seems as if my adjuster is just rotating around the threaded piece there, not having any way of adjusting a thing!.
Old Nov 5, 2009 | 09:18 AM
try holding the threaded part, and then spinning the adjuster, sounds like they are kinda frozen together. Its not a fast adjustment tho, it takes more then you'd think to move the needle a little bit
Old Nov 5, 2009 | 09:31 AM
WowGuyF150's Avatar
Yea. i went all way one way then all the way the other. How exactly does it work? My little plastic mount piece is broken, but that doesnt look like it would affect anything, just hold the cable away from anything and in place. I just cant see how spinning the spinner along the threaded piece moves the cable at all. Unless mine is messed up like you said. Cant be frozen together though because the spinner is moving freely up and down the threaded portion...
Old Nov 5, 2009 | 09:50 AM
the bracket is what the adjuster pulls against, so if the bracket is broken it has no point to pull from
Old Nov 5, 2009 | 10:38 AM
WowGuyF150's Avatar
that is what I JUST realized looking at it underneath there a bit closer and the pics in the original post. Thats where it gets its tension from...yea mines broken, which is probably why it's so out of position....anyone have an extra?? sucks
Old Mar 27, 2012 | 08:40 PM
chrmar's Avatar
An old thread but... the pictures are broken. Any chance of seeing those again, Pat?
Old Apr 17, 2012 | 10:12 PM
yup got these back up and running, i had hosted them here, and changed the technical article pictures, but never changed them here.
Link to the technical article https://www.f150online.com/forums/ar...inter-fix.html
There are several good posts in there about others that have had broken brackets and how they fixed them.
-Patrick
Old Apr 18, 2012 | 06:14 AM
chrmar's Avatar
Awesome. I'll try and adjust mine as soon as I get it back from the shop. Not sure if there's enough adjustment left in it as it points to R when in P... gave me a bit of a scare when I first picked up the truck and tried to take off in N (it pointed to D).
Old Apr 18, 2012 | 09:21 AM
your bracket is probably broken if its that far off
Old Apr 20, 2012 | 07:52 PM
chrmar's Avatar
You're right, the bracket is broken. I got my fiancee to watch the needle as I jiggled the cable around so I have it adjusted to where it needs to be, I just need to get it to stay there. Time to start looking for a fix!
Old Apr 20, 2012 | 10:19 PM
check that other thread I linked a couple posts up about how to fix it, other members have some suggestions
