No reception
Old Nov 1, 2009 | 02:06 PM
wutagoalie's Avatar
No reception
Hello all, i recently replaced my heater core in my 99 4.6L 2wd.
Ever since i pulled the dash out and put it back in, i only get local radio stations, where as before i would get stations from areas hours and hours away. It is almost like i lost signal power. I pulled out the radio and made sure the antenna wire was plugged in properly at the back of the radio , as well as the other end that plugs into the antenna it self. They were both ok, what is my next step?
Old Nov 3, 2009 | 07:33 PM
wutagoalie's Avatar
Is this stumping everyone ? At this point im not sure what else to do!
Old Nov 3, 2009 | 08:01 PM
Red02FX4's Avatar
On Some vehicles... the antennae lead comes thru the fender then has a secondary lead to the radio... did you notice anything like this during your repair?
Old Nov 4, 2009 | 08:19 AM
patco's Avatar
On my 97' 150 I discovered that water had crept down my radio antenna coax and had corroded it internally and wasnt visible untill i pulled it in two with little effort. this also had not been realized untill after i replaced my heater core and had diss and then reconnected coax at rear of radio.reception was restored after replacing antenna/coax assembly. hope this maybe helps.
patco's Avatar
Old Nov 4, 2009 | 09:14 AM
jbrew's Avatar
Check your continuity from inside to out. You may have pinched the cable putting her back together. Probably easier to disconnect the old and just run a new line if that's the case.
Old Nov 4, 2009 | 06:59 PM
wutagoalie's Avatar
Thanks guys, i will inspect the line and check it for continuity.
By the way, is the line 1 piece from radio to antenna , or 2 pieces?
