Smelling Antifreeze
Old Oct 30, 2009 | 08:52 PM
milscoe's Avatar
Smelling Antifreeze
1999 F-150 wheel drive, 4.6. automatic. The radiator is building up pressure, the top hose swells up, I replaced the cap and it worked at first but is building up pressure again. I have had a manifold leak for a while, could this have anything to do with it?
Old Oct 30, 2009 | 09:47 PM
Drexelsteve's Avatar
It could. Or the thermostat could be stuck. Is it overheating?
Old Oct 30, 2009 | 09:51 PM
milscoe's Avatar
The thermostat is good, I replaced it last year. It is not overheating
Old Oct 30, 2009 | 09:56 PM
Red02FX4's Avatar
replace the hose. sounds like it developed a soft spot
Old Oct 30, 2009 | 10:35 PM
milscoe's Avatar
Thanks, I will try that
Old Nov 4, 2009 | 10:25 PM
90taz's Avatar
were are you smelling the anti freeze, is it in the cab if so the heater core is leaking. usually you will see the anti freeze leaking out of the condensation tube for the ac.
Old Nov 9, 2009 | 09:38 PM
milscoe's Avatar
We are smelling the anti freeze, when we are outside. I can't find anywhere that it may be leaking though.
Old Nov 9, 2009 | 10:20 PM
Red02FX4's Avatar
did you check things like engine side of radiator... maybe behind fan shroud... and/or leaking freeze plugs ( just to cover all the bases)
