2001 f150 Supercrew wont start
Old Oct 17, 2009 | 09:40 PM
graffspee's Avatar
I have a 2001 f150 Supercrew that wont start. I replaced the starter but all I get is a clicking sound . The Battery is new. I am at a loss at the moment.
Any Ideas??????
THANKS
Mike
Old Oct 17, 2009 | 09:55 PM
gauge_one's Avatar
try to test out the solonoid or however u spell it.
Old Oct 17, 2009 | 10:06 PM
torkum's Avatar
Did your old starter check out bad? If so recheck all your connections. Make sure the connectors are clean.
Old Oct 17, 2009 | 11:00 PM
jethat's Avatar
I've replaced many a good Ford Starter.. They rarely fail. Always start with the easy cheap stuff first. Connections... Relay. Try shorting the big post to the small post on the firewall relay. If the starter engages replace the relay and your good. While you at it check and clean all connections..
Old Oct 18, 2009 | 08:29 AM
graffspee's Avatar
Ok, I tried Shorting the post on the firewall relay and all I got is the click sounds. I also noticed that when I turn the key to the on position all the gages peg to the right then go back to the other side and if I try to start I just get the clicking noise... Wondering if the new battery is bad? or could a bad relay also cause that?
Old Oct 18, 2009 | 09:31 AM
yah if the gauges peg out like that the battery is dead. Or the battery terminals are so corroded the truck can't get enough power out of the battery
Old Oct 18, 2009 | 09:51 AM
graffspee's Avatar
I solved the issue.... It was the battery cables. I had a bad connection....
Well I am only $200 in the hole for the starter. Wish I would have checked the cables before jumping to the conclusion that it had to be the starter. Oh well, it works now so I am happy..THANKS to everyone for the help. It pointed me into the right direction and I learned something new....
CHEERS
Mike
Old Oct 18, 2009 | 11:51 AM
jethat's Avatar
CHEERS
Mike
You'll remember next time..
