Installed Lights behind Grill
Old Nov 25, 2009 | 01:19 PM
bohnman's Avatar
Never mind I found the size but I'm interested in anybody has done this with A/C
Old Nov 25, 2009 | 05:19 PM
4.2trimble's Avatar
great job man
Old Nov 26, 2009 | 07:36 AM
EBXGSXR's Avatar
looks amazing. very very nice installtion job. want to come to MD and do mine
Old Nov 26, 2009 | 11:38 AM
fairlaner's Avatar
Thanks! Keep in mind I have a great talent for making a simple job complicated ... installing the lights is easier than I made it look.
No plans for a trip to MD, but on your next road trip to Cali, swing by the house and we'll put them in, lol
My truck has A/C (I'm assuming you're talking about air conditioning)... it doesn't affect the installation. If you're concerned about whether the lights blocking the air to the radiators will affect A/C operation, I have no answer on that for you.
Old Nov 30, 2009 | 01:33 PM
bohnman's Avatar
Sorry yea I thought that you didn't have A/C I thought that the condensor was missing from your pictures. Going to do this probably come summer. Looks really cool.
Old Nov 30, 2009 | 08:13 PM
b-ryan's Avatar
well im planning on doing that tomorrow during shop class but with4x6 farm lights (to cheap to buy real off road lights that will all ready be distorted by the grill)
Old Dec 1, 2009 | 08:53 AM
wmrawls's Avatar
Very nice, thanks for sharing your work.
Old Jan 2, 2010 | 11:31 PM
Ace_boy2099's Avatar
Originally Posted by fairlaner
To get the lights to operate as stock (only on w/ low beam), I connected Pin 86 on the relay to the WH/BK wire on the light switch, and Pin 85 on the relay to the yellow wire on the switch. I consulted the wiring diagram for my ‘99 for this setup, and I believe it is correct for ‘97-‘99 (if it’s not, someone please correct me ... I’m pretty much a novice when it comes to anything electrical). I think the ‘00+ are wired differently. On a side note, the light switches for the ‘97-‘99 are different than the ones for the ‘00-‘03, although they look very similiar in the cab.
They work!!
so you are saying that the white/black stripe wire and the yellow wire if for the fog operation? With that set-up and another topic i found on this i am taking it that the white/black is the fog light wire and the yellow is suppose to be the ground? Any help you can provide me with for this I would be greatly appreciative as I am trying to do this myself.
Edit: I just looked at the back of my headlight switch and I didn't see a white w/black wire there that only activated with the foglight switch engaged, If you can take a pic of the back of the switch so I can see what wires you are talking about so I can do this I would be GREATLY appreciative.
Old Jan 3, 2010 | 10:36 AM
FordGuy24's Avatar
Nice job and great write up!...PTM looks awsome
Old Jan 3, 2010 | 12:41 PM
fairlaner's Avatar
First, keep in mind I'm REAL weak when it comes to electrical. I've now run the lights for several months w/ no issues, so I'm assuming my connections are OK.
From the wiring diagram posted below, it appears the yellow is for the switch w/ the white/black for the ground. The note that reads "directs power to energize fog lamp relay" is what led me to connect the white/black wire the way I did.
The white/black wire comes from the small gray plug on the right
I hope this helps you out. It amazes me how much I'll forget about how I did something just a few months earlier ...
Old Jan 3, 2010 | 01:07 PM
Well, It all depends on when the people find the threads, I for example only joined this forum last week I think it was and spent the past couple days between fixind things wrong with the truck, modding really easy mods, and reading topics on what I was looking into doing to the truck.
Looks like the two big plugs to the left look the same as mine but the little grey one to the right is missing some wires compared to mine. I will get a pic in a min what features does your truck have? I know you did fogs yourself but do you have DRLs or Autolamps?
Edit: Here is the pic I just got of the back with the wires
From what I can see the wires are as follows: (Looking down at back of plugs after pulling from dash and bending light switch to face floor)
_______________________________ __________________________________________ __________________________________________________ ___________
|Brown | Brown/WhiteStr | Orange | | Blue/OrangeStr | Red/TanStr | Lt.Blue/RedStr | | Green/YellowStr | Purple/OrangeStr | Blue/OrangeStr | Tan/BrownStr |
|Blue/WhiteStr | White/RedStr | N/A| | Black | Yellow | Lt.Blue/BlackStr| EMPTY | __________________________________________________ ____________
Edit 2: Oops , I had mis-read you late statement. I know what you mean though. Happens to me alot, I'll do something then a week later forget what the heck I did.
Old Jan 4, 2010 | 03:29 AM
Stephen87's Avatar
I am tagging this for later use
Old Jan 4, 2010 | 07:55 AM
Veteran: Army
looks great
now time to paint that chrome on the bumper, it looks way out of place now
Old Jan 4, 2010 | 09:36 PM
fairlaner's Avatar
Ace_boy2099, my truck is a XL (base model), so it wasn't equipped w/ autolamps (or much else for that matter ...). The white w/ black stripe wire I connected to is on the right side of the small plug on the right in your picture (it's actually two wires). The yellow wire is in the larger black connector in the center of your pic.
Old Jan 28, 2010 | 04:04 PM
Thanks Fairlaner, I just did this in my truck and they work. Now I am just waiting for the HIDs to come so I can use them. When I take the switch apart to change the light in it (trying to go to blue eventually) I plan on doing the mod to make the fogs work in all modes.
