Lift or Lower?
lift it- 1.5" daystar spacer and some 285/75/16s on stock wheels or 265/75/16s on aftermarket wheels
my new truck at stock height with 265/75/16s and aftermarket wheels
my new truck as it sits now
Did your lift cause the tires to stick out that much in the front? Or is that just an illusion? Looks a lot different from the before pic. Looks good.
Thanks. Ive always liked your truck as well. It’s taken a while but I’m happy with how she looks now. Yeah the spindle lift pushed the front tires out plus I'm running a tiny spacer for break caliper clearance with the wheels. Rear wheel spacers are in the plan to make them stick out equally.
do a body lift, and then run 33's on your rims you have now. you have a 4 wheeler so i would assume you would go try and push through mud, even if you didnt have 4 wheel drive. haha but its up to you man!
Well here is a couple of pics The light setup has changed slightly.
Before wheels
After wheels
and one showing part of the front end
I also have some others in my gallery, but I just realized that I don't have any with my tail light gaurds so I need to go take a couple of those.
Before wheels
After wheels
. I am still biased though. Sheesh
