shakin screw
Old Sep 27, 2009 | 06:24 PM
RathF150's Avatar
shakin screw
So my parents 2001 supercrew shakes under acceleration when turning and gets worse as the truck warms up.this has been going for about 2 months. It's not an unbearable shake but well noticed
My first thought was u-joints but a while ago the shop said they were fine
a bad front wheel bearing was just replaced
Truck is 4x4, 5.4 has 154,xxx miles
and is all stock
Any thoughts on the problem, u joints?, axles? bearings?
Old Sep 28, 2009 | 12:30 AM
If it has a limited slip axle, it may be clutch pack chatter. Change the lube (75W140 full synthetic) and add a bottle of friction modifier.
Old Sep 28, 2009 | 01:13 AM
b2therad's Avatar
I doubt very seriously whether or not heating up would effect this or not, but what kind of shape are the inner tie rods in? I had one that was bad that made my steering wheel shake around a bit. Had no idea what it was till I got under there and noticed the rubber boot on the end about to fall off
Old Sep 28, 2009 | 09:52 PM
RathF150's Avatar
alxe lube was changed last spring
don't think its a tierod cause it's not in the wheel it's the truck
could it be a bearing in the rearend
Old Oct 7, 2009 | 08:35 PM
Bueller's Avatar
Broken belt in a tire will do that too
Frank
Old Oct 7, 2009 | 10:01 PM
RathF150's Avatar
sounds reasonable but would that account for it getting worse as it warms up
Old Oct 8, 2009 | 12:57 AM
The axle lube may have been changed last spring, but was it changed with 75w140 full synthetic and friction modifier?
Old Oct 8, 2009 | 08:37 PM
RathF150's Avatar
Not sure
