Plug change now Misses
Old Sep 20, 2009 | 04:43 PM
jbrew's Avatar
Originally Posted by Night05
will I need to take plugs out and clean the spark plug tip as well
You can, if you prefer, I would just shove a rag down the chamber with a grease cutting agent. You just need to clean the top of the plug.
Night05's Avatar
thanks jbrew There is no mention of dielectric grease is this step necessary?
Old Sep 20, 2009 | 04:49 PM
Night05's Avatar
Ok looks like after it cools down i will be pulling cop's again and cleaning and reinstalling any suggestions on the gas that spills any tips or concerns upon startup thanks
Old Sep 20, 2009 | 04:59 PM
jbrew's Avatar
Dielectric is the grease I'm referring to at the bottom of page one. Infact, that's the ONLY grease I'm referring to.
Old Sep 20, 2009 | 05:00 PM
jbrew's Avatar
I lay a bunch of rags around everything before I pull the rail. Also when reinstalling, there's always a little gas the works it's way in there when stationary. You wrap rags around that as well, -yea keep ip it dry as you can.
Old Sep 20, 2009 | 05:04 PM
Night05's Avatar
Ok I follow your description fine. I was refering to the link you provided it didnt metion grease thank you for you time I am going to give it another go and be less generous with the grease
Old Sep 20, 2009 | 05:06 PM
jbrew's Avatar
Yea, I know Matt doesn't say much about greasing, that's why I wondered if anyone else has done a write-up lol.
Old Sep 20, 2009 | 05:12 PM
Night05's Avatar
OK well i hope this is the solution if any parts r needed do any sites you know of sell cop's or new injectors preferably oem @ reasonable price I hear full sets of cop's r cheaper than individuals and how do i know if the injectors didnt get debris into the causing the miss
Old Sep 20, 2009 | 05:40 PM
You can buy a full set of OEM quality cops on Ebay for around 80 bucks - look for listings from Global Automotive or Uneek Supply. What you want are DG508's.
Old Sep 20, 2009 | 06:08 PM
Night05's Avatar
thanks for all your help now its time to get my hands dirty
Old Sep 20, 2009 | 06:20 PM
jbrew's Avatar
Yep, OEM's right here -
http://cgi.ebay.com/ebaymotors/NEW-I...ht_2539wt_1165
Old Sep 20, 2009 | 06:45 PM
jbrew's Avatar
Almost forgot, not sure if it's been mentioned yet, - DON'T use Anti seize on the plugs. If you do, you have to reduce torque by 30-40 %. If their over torqued right now, lord have mercy lol.
It's allot safer not to use, you don't need it. If you torqued them dry, your perfect
Old Sep 20, 2009 | 07:19 PM
Night05's Avatar
did not torque them dry matt site said use antiseeze they were set to 20#
Old Sep 21, 2009 | 12:43 AM
jbrew's Avatar
Since their set at 20, you should probably be okay. Not sure, but glc knows the max torque on those and I believe your in safe territory. Max is listed here somewhere -
http://www.blownoutsparkplug.com/
Personally I don't use a torque ratchet on those, I just go 1/4 - 1/2 turn after snug or after their run down. I believe it says this on the box, well it does on mine, I use Denso's tho.
Old Sep 21, 2009 | 01:09 AM
If you antiseized them, torque them to 30. The heads are safe to 100.
