humming noise
Old Sep 15, 2009 | 11:55 AM
F150man21's Avatar
humming noise
so my dads truck is having a weird problem. its a 2002 4.6 82k 2wd screw, the problem is that when you get up to about 40mph there is is loud humming noise coming from the front end. it kinda sounds like a tire noise but its not. theres really no problem with the truck(power loss etc.) but my dads kinda paranoid about it.
thanks
Old Sep 15, 2009 | 11:57 AM
May be a front wheel bearing starting to go.
Old Sep 15, 2009 | 12:09 PM
F150man21's Avatar
yea thats what he was thinking, guess we'll take a look.
thanks
Old Sep 15, 2009 | 12:14 PM
The bearings develope pits in them from water or lack of grease and when they roll over the race, it makes a humming noise. Will only get worse it that is it.
Old Sep 23, 2009 | 06:55 PM
sjsjbb's Avatar
had same thing happen 2001 screw here. bought mine at junk yard 40.00 off same year truck. works great and not hard to change. compared to 250. front wheel hub bearing
Old Sep 24, 2009 | 12:03 AM
maddoughboy's Avatar
Depending on the set up you can eat your hub or race also then having to replace those as well.
Old Sep 24, 2009 | 07:03 AM
jutwan88's Avatar
Take it out for a drive and when it starts making the humming noise hold your speed and go left to right with the wheel. Sound should get worse when you load up on the side that is bad. Then jack up the front end and check for play.
Old Sep 24, 2009 | 09:49 AM
ChrisT's Avatar
^ good point. I did notice that on mine when I would turn slightly to one side. Front wheel bearings on mine went around 85K also.
Old Sep 24, 2009 | 11:24 AM
F150man21's Avatar
fixed it, it was a front wheel bearing.
thanks
Old Nov 6, 2009 | 09:19 PM
Manitoba 150's Avatar
I changed my bearings a couple of months ago. Left side first then the right side went.
I get the humming with the wheel to the left. Are the left ones bad when this happens? I packed them pretty well with grease maybe not enough. I didn't change the seal. Could that be a propblem? Its a 98 2wd.
Old Nov 6, 2009 | 10:17 PM
Adding to my last post.
Turn the wheel right I have humming, turn to the left its quiet. Does that mean the right side is going? When I changed the bearings. Left side, inner and outer. Right side just the outer. Did not change the inner seal on either side. Should I have changed both bearings at the same time on the right side aswell as the seals?
Old Nov 7, 2009 | 09:35 PM
Well it would be good insrance to do so since you already had it a part it wouldn't have been that much more.
Old Nov 8, 2009 | 03:00 AM
If it hums when you turn the wheel right it's the left bearing that's under load and that's the one which is bad. It's usually a good idea to replace both bearings and the seals. You also need to inspect the spindle and the bearing races.
