help me
Old Aug 9, 2009 | 08:25 PM
4x4Nixon's Avatar
help me
noob here...
im looking at new tires and rims for my truck but i cant figure out what rim specs to go with or what size tires to get. i want the tires to stick out pretty far for a off road stance and im looking at either a 17" rim or a 18" rim. yall guys got any suggestions for me let me no. thank you
Old Aug 9, 2009 | 09:53 PM
wandell's Avatar
I assume you have a 4x4 because of your name. Go with a 10 inch wide wheel with 4.5 inches of backspacing. If you are stock height, go with a 33x12.50 tire. This will put the edge of the tire/wheel just about even with the edge of the fender flares. I have pics in my gallary if you want a visual. You will have to trim a litttle plastic off the front bumper's lower valance for clearance. I'd also crank up the torsion bars enough to level the truck.
Old Aug 9, 2009 | 10:07 PM
4x4Nixon's Avatar
great info thank you. yeah i got 4x4 and i also just recently cranked my torsions. i love the leveled look but is it the lower the backspacing the wider it will be? oh yeah and whats the offset or your wheels?
Old Aug 9, 2009 | 10:13 PM
wandell's Avatar
The less backspacing, the more the wheels sticks out. My wheels are 16x10 with 4.5 inches of backspacing. That is the most common spec for a 10 inch wide wheel for our trucks.
Old Aug 9, 2009 | 10:19 PM
31 YNOT's Avatar
i have the same set up as wandell, it looks great
Old Aug 9, 2009 | 10:20 PM
4x4Nixon's Avatar
yeah i think i might just go with a mickey thompson 16x10 and a 33x12.50. its hard to find rims with our bolt pattern these days. i was thinking about getting a wheel adapter to change the bolt pattern to a 6x135 because i was really looking at the moto metals you think that be a good idea or not?
Old Aug 10, 2009 | 11:52 AM
wandell's Avatar
No, they are a bad idea. Not only do spacers/wheel adaptors cause problems like vibrations but they will push the tire/wheel outward causing ftment problems.
Old Aug 10, 2009 | 12:15 PM
_cashel's Avatar
How much more, on average, would it be to buy 'blank' wheels and have them drilled to our bolt pattern?
Old Aug 10, 2009 | 01:47 PM
4x4Nixon's Avatar
well screw that idea about adapters. and thats a good question i would like to no how much it would be to if anybody ever done that before?
Old Aug 10, 2009 | 09:52 PM
wandell's Avatar
Good question.
