please help!!!!
Old Jul 25, 2009 | 11:13 PM
glenwood27's Avatar
please help!!!!
i have a 1999 f150 4x4 with a 4.6 in it i was tourning the corner the other day and i was not in 4x4 and the driverside axle poped out of the diff and the gear oil came out i was just woundering what the problem could be and how i should go about fixing this ?
Old Jul 26, 2009 | 12:31 AM
glenwood27's Avatar
the plate that the axle bolts to has come right out of the diff
Old Jul 27, 2009 | 12:14 AM
front or rear?
I think fronts just press in, you probably have a bad CV joint and it got stiff and wallowed the hole out and then it just fell out
Old Jul 28, 2009 | 01:33 AM
glenwood27's Avatar
i took it apart today theres clips that holds them inplace just like on the rear ones and nothing else got damaged in the front diff so all was good now i just have to find what gear oil would be the best to refill it with because i snowplow and also how i crank up the tortion bars in the front
Old Aug 2, 2009 | 04:08 PM
The front axle specs for 80W90 conventional gear oil.
