fuses
There is a list in your owner's manual. If you don't have it, download it.
https://www.fleet.ford.com/maintenan...ls/default.asp
That said, check your brake light switch.
In my 03 manual, it's fuse #13 in the inside box - labeled "stop lamp switch (Lamps)". It also feeds the 4 way flashers and turn signals. If your 4 ways and turn signals work, you probably have a bad or out of adjustment stoplight switch itself. This is a common failure.
did it
you were right. i replaced the fuses for the "stop lamp", nothing. replaced the bulbs, nothing. replaced the stop lamp switch, attached to the brake pedal, and SUCCESS!!! Thanks for the input. still a little strange, because i just had the truck inspected last week, and everything worked just fine. guess i got lucky.
